mrprotokoll wrote on Thursday, October 11, 2012:
Sorry, was the wrong link. I can’t find the correct one.
Only the init sequence seems to be different, so i will post he correct one here. I have made some extension to the code to handle those 4 serial interfaces.
* \brief Init the serial port.
* \param UsartId The identifier of the Usart to init.
* \param ulWantedBaud The required baudrate.
* \param uxRxQueueLength The length of the Rx buffer (if 0, rx is not supported).
* \param uxTxQueueLength The length of the Tx buffer (if 0, tx is not supported).
* \return xComPortHandle Handler on the COM port.
xComPortHandle xUsartInit( eCOMPort UsartId, unsigned portLONG ulWantedBaud,
unsigned portBASE_TYPE uxRxQueueLength,
unsigned portBASE_TYPE uxTxQueueLength)
xComPortHandle xReturn;
xUsartPrivateData *pxUsart;
int UsartRxEnMask = ((uxRxQueueLength==0) ? 0 : AVR32_USART_CR_RXEN_MASK);
int UsartTxEnMask = ((uxTxQueueLength==0) ? 0 : AVR32_USART_CR_TXEN_MASK);
int iTempoStatus;
// USART options.
usart_options_t USART_OPTIONS =
.baudrate = 57600,
.charlength = 8,
.paritytype = USART_NO_PARITY,
.stopbits = USART_1_STOPBIT,
.channelmode = USART_NORMAL_CHMODE
USART_OPTIONS.baudrate = ulWantedBaud;
// xReturn = pxUsart = (UsartId == serCOM1 ? &xUsart0 : &xUsart1);
if (UsartId == serCOM1)
pxUsart = &xUsart0;
xReturn = pxUsart;
if (UsartId == serCOM2)
pxUsart = &xUsart1;
xReturn = pxUsart;
if (UsartId == serCOM3)
pxUsart = &xUsart2;
xReturn = pxUsart;
if (UsartId == serCOM4)
pxUsart = &xUsart3;
xReturn = pxUsart;
/* Create the rx and tx queues. */
iTempoStatus = iprvSerialCreateQueues( uxRxQueueLength, &(pxUsart->xRxedChars),
uxTxQueueLength, &(pxUsart->xCharsForTx) );
/* Configure USART. */
if( ( iTempoStatus != pdFAIL ) &&
( ulWantedBaud != ( unsigned portLONG ) 0 ) )
portENTER_CRITICAL();
** Configure USART.
/* Enable USART RXD & TXD pins. */
if(UsartId == serCOM1)
if(uxRxQueueLength)
gpio_enable_module_pin(AVR32_USART0_RXD_0_1_PIN, AVR32_USART0_RXD_0_1_FUNCTION);
// gpio_enable_module_pin(AVR32_USART0_RXD_0_0_PIN, AVR32_USART0_RXD_0_0_FUNCTION);
if(uxTxQueueLength)
gpio_enable_module_pin(AVR32_USART0_TXD_0_1_PIN, AVR32_USART0_TXD_0_1_FUNCTION);
// gpio_enable_module_pin(AVR32_USART0_TXD_0_0_PIN, AVR32_USART0_TXD_0_0_FUNCTION);
if(UsartId == serCOM2)
if(uxRxQueueLength)
gpio_enable_module_pin(AVR32_USART1_RXD_0_1_PIN, AVR32_USART1_RXD_0_1_FUNCTION);
// gpio_enable_module_pin(AVR32_USART1_RXD_0_0_PIN, AVR32_USART1_RXD_0_0_FUNCTION);
if(uxTxQueueLength)
gpio_enable_module_pin(AVR32_USART1_TXD_0_1_PIN, AVR32_USART1_TXD_0_1_FUNCTION);
// gpio_enable_module_pin(AVR32_USART1_TXD_0_0_PIN, AVR32_USART1_TXD_0_0_FUNCTION);
if(UsartId == serCOM3)
if(uxRxQueueLength)
gpio_enable_module_pin(AVR32_USART2_RXD_0_1_PIN, AVR32_USART2_RXD_0_1_FUNCTION);
if(uxTxQueueLength)
gpio_enable_module_pin(AVR32_USART2_TXD_0_1_PIN, AVR32_USART2_TXD_0_1_FUNCTION);
if(UsartId == serCOM4)
if(uxRxQueueLength)
gpio_enable_module_pin(AVR32_USART3_RXD_0_1_PIN, AVR32_USART3_RXD_0_1_FUNCTION);
if(uxTxQueueLength)
gpio_enable_module_pin(AVR32_USART3_TXD_0_1_PIN, AVR32_USART3_TXD_0_1_FUNCTION);
// Initialize USART in RS232 mode.
usart_init_rs232(pxUsart->usart, &USART_OPTIONS, CP_PBA_SPEED);
/* We're not fully done yet: disable receiver and transmitter. */
pxUsart->usart->cr |= AVR32_USART_CR_RXDIS_MASK | AVR32_USART_CR_TXDIS_MASK;
// Register the USART interrupt handler to the interrupt controller and
// enable the USART interrupt.
INTC_register_interrupt((__int_handler)&vUSART0_ISR, AVR32_USART0_IRQ, AVR32_INTC_INT2);
INTC_register_interrupt((__int_handler)&vUSART1_ISR, AVR32_USART1_IRQ, AVR32_INTC_INT3);
INTC_register_interrupt((__int_handler)&vUSART2_ISR, AVR32_USART2_IRQ, AVR32_INTC_INT1);
INTC_register_interrupt((__int_handler)&vUSART3_ISR, AVR32_USART3_IRQ, AVR32_INTC_INT1);
/* Enable USART interrupt sources (but not Tx for now)... */
if(uxRxQueueLength)
pxUsart->usart->ier = AVR32_USART_IER_RXRDY_MASK;
/* Enable receiver and transmitter... */
pxUsart->usart->cr |= UsartTxEnMask | UsartRxEnMask;
portEXIT_CRITICAL();
xReturn = serINVALID_COMPORT_HANDLER;
return xReturn;
