I have been struggling with the implementation of a "Serial-Ethernet bridge" for quite few weeks. If anyone has an idea kindly reply on the following query (Thanks in Advance):
On sending continous data (@115200) on the serial port (UART async rs232) for around 7-8 hrs, the serial interrupt stops triggering (I have verified this by putting a break point in the UART IRQ handler routine, when the problem occured. I am using IAR embedded workbench).
Following is the implementation:
- The UART IRQ handler fills the data into a queue (using xQueueSendFromISR).
- A free running task keep waiting on the queue & whenever there is any data in the queue, it forwards it to the TCP (tcp_write & tcp_output).
- This bridge is just a part of the system, in all there are around 10 tasks running in the system.
Maybe you’re not freeing some pbufs, or some other task is disabling serial interrupts after some time. IMHO,
these kind of problems are hard to track. If I were you, I would:
1st : Remove all other tasks and just forward data to the ethernet port. This will help localizing the problem.
2nd : Check if ethernet is working after serial interrupts stop working.
you are write. I have already made a setup running with only the bridge task…I may have results after another 7-8 hrs…btw ethernet was working when the serial interrupt stopped…I would share the results tomorrow morning (my morning INDIA :)…Thanks for the reply…
I had a problem like this : when i was enabling a RTC interrupt on my STR912, my software was reseting after 3-4-6 hours of running… I don’t know if you are in this case or not…
OtherWise: the usual problem of stack overflow could be interesting to check, if not already done…
I write the following code to look the memory usage of each task, the function is the following (this function locate in the stack the last: 0xa5a5a5a5)(To use it, you need to cut - copy the structure definition: tskTCB to a *.h file to ‘export’ the type)(UTILS_TRACE_STACK is used as a printf function (vsprintf) to send debug info to an hyperterminal)
Another thing you can check is the stack available in IRQ mode.
Damien
* \fn u8 UTILS_PrintStackUsage (xTaskHandle TaskHandle)
* \brief This function will print (trough RS232) information about stack usage on a dedicated task
* \return Always 0
tskTCB *TaskStack = (tskTCB*)TaskHandle;
u32 *CurrentCell;
if (TaskHandle != NULL)
//print direct available info
UTILS_TRACE_STACK2("---- %s ----",TaskStack->pcTaskName);
UTILS_TRACE_STACK3("Stack Start - End : 0x%.8x - 0x%.8x",TaskStack->pxStack,TaskStack->pxTopOfStack);
// init the current memory cell on the beginning of the task
CurrentCell = TaskStack->pxStack;
