Having a problem building any of the non-Cortex ARM demos under Keil RealView compiler uVision3 V3.62c.
The embedded assy in the file \Source\portable\Keil\ARM7\portmacro.h generates many syntax errors:
Source\portable\Keil\ARM7\portmacro.h(131): error: #40: expected an identifier
Source\portable\Keil\ARM7\portmacro.h(131): error: #666: "asm" must be used with a function definition
Source\portable\Keil\ARM7\portmacro.h(131): error: #65: expected a ";"
etc…
Thanks. I got the LPC2138_Keil_RVDS_MCB2130_FD project to build once I added an ro-base value. The SAM7 project would probably build too if I wasn’t using the size limited eval.
