I’m using FreeRTOS on a dsPIC and want to give a semaphore from an ISR. The xSemaphoreGiveFromISR macro is being called but in all of the documentation it talks about yielding from within the ISR. The actual implementation depends on the port. some ports use taskYIELD. There is a version for the PIC32 that is named portEND_SWITCHING_ISR but I can’t find an implementation for the dsPIC. Has anyone implemented this and if so, do you want to share the solution? I’m in crunch mode and don’t have time to re-invent the wheel. If nobody has the solution I will implement it and post the code for all to use.
See the “Interrupt Service Routines” section of http://www.freertos.org/portpic24_dspic.html, and the example in _U2RXInterrupt() defined within FreeRTOS\Demo\PIC24_MPLAB\serial\serial.c.
Thank you for the replies. I used the taskYIELD() function and it seems to be working fine. I’m having stack overflow problems but I’m convinced it’s elsewhere in the code. I had tried the taskYEILD before but thought it was causing the stack overflows. Now I’m pretty sure it’s not the cause.
