aviasaf wrote on Wednesday, February 18, 2009:
hello all,
I am working on atmel at91sam7s256 base on IAR workbench 5.00.
the semaphore example which appears in FreeRtos Web site uses portYIELD_FROM_ISR macro,
its being called after xSemaphoreGiveFromISR and if xHigherPriorityTaskWoken was set to true.
first of all, I would like to understand, what is the Yield macro role ? is it uses in order to force a context switch after the interrupt routine is ended?
second, I didn’t found portYIELD_FROM_ISR macro at all, so I was trying to use “taskYIELD” but the OS was crashed.
what am I doing wrong?
does any one can help me with that problem?
thanks,
