I have the following code:
In the setup/init function:
//Create Apply Timeout Timer
app_applyData.xTimer_Handle_ApplyTimeout = xTimerCreate("xSoftTmr_ApplyTimeout",
xPrinterData.uiApplyErrorTimeout,
pdTRUE,
( void * ) 0,
CBK_SoftTmr_ApplyTimeout);
In the function where I start the timer:
//set timeout time and start timer
xTimerStop(app_applyData.xTimer_Handle_ApplyTimeout, 0);
xTimerChangePeriod(app_applyData.xTimer_Handle_ApplyTimeout, xPrinterData.uiApplyErrorTimeout, 0); //reset time period to 100ms because there is no point in sampling faster
xTimerStart(app_applyData.xTimer_Handle_ApplyTimeout, 0);
Then is a ISR callback the following code (this is the entire callback):
void CBK_ChangeNotif_ApplicationGap(GPIO_PIN pin, uintptr_t context)
//Check which edge this INT was generated by
if (APPLIC_GAP_Get() == 0)
//INT was generated by falling edge (gap to label transition)
_nop();
//An edge was sensed so stop the timer to prevent timeout
taskENTER_CRITICAL();
//set local flag that label edge has been detected
app_applyData.bLabelEdgeDetected = 1;
if (app_applyData.bApplyStopByStepCount == 0)
//clear the flag that the motor is running (because the motor is being stopped)
app_applyData.bApplyStepperIsRunning = 0;
//stop motor and timer
OCMP6_Disable();
TMR3_Stop ();
//redundant torque reduction. But placed here too for safety
Stepper_Apply_SetTorqueToThird();
taskEXIT_CRITICAL();
//INT was generated by rising edge (label to gap transition)
_nop();
_nop();
If I comment out the
then the code runs as it should. Otherwise it doesn’t.
And what happens exactly is that none of the other interrupts that occur are serviced after then.
what could cause that?
have a number of software timers. Are there limits to the number of software timers I can create? Do I have to perhaps set some config variable somewhere?
UPDATE
Another thing that occurs if I leave that specific line in while debugging is that the debugger throws an exception and a software breakpoint with no functions shown in the call stack and the only information is a exception code of the MCU core itself. The only information on that code in the silicon manual is Bus Error Exception (instruction fetch). Nothing more. You can see entry/code 6 in table 2.10 on page 42 of the pdf here:
http://hades.mech.northwestern.edu/images/b/b1/PIC32RefManual-Dec2013.pdf
Thank you
Thank you.
