account002 wrote on Sunday, August 31, 2014:
Making a FreeRTOS project for TI Hercules RM48 microcontroller.
Got a problem with Software Timer functions (xTimerCreate(), xTimerReset(), xTimerStop() etc.):
calling any of then inside a task causes a PREFETCH exception of the microcontroller.
Calling them inside main function is ok.
FreeRTOS v.7.4.0
Parameters from FreeRTOSConfig.h
#define configUSE_TIMERS 1
#define configTIMER_TASK_PRIORITY ( configMAX_PRIORITIES - 2 )
#define configTIMER_QUEUE_LENGTH 10
#define configTIMER_TASK_STACK_DEPTH ( 128 )
The code
#include "sys_common.h"
#include "het.h"
#include "gio.h"
#include "FreeRTOS.h"
#include "timers.h"
#include "task.h"
void vTask1(void *pvParameters);
uint32 i = 0;
xTimerHandle xTimer1;
// Timer callback function
void vTimerFunction(xTimerHandle xTimer)
// toggle port bits
gioToggleBit(hetPORT1, i);
i++;
if (i>31)
i=0;
// restart timer
xTimerReset(xTimer1, 0);
// Main function
void main(void)
// configure port direction (outputs)
gioSetDirection(hetPORT1, 0xFFFFFFFF);
// configure port output pins initial value
gioSetPort(hetPORT1, 0xFFFFFFFF);
// creating task
xTaskCreate(vTask1, (const signed char *)"TimerStart", 1024, NULL, (configMAX_PRIORITIES - 3), NULL);
vTaskStartScheduler();
while(1);
// Task function
xTimer1 = xTimerCreate((const signed char *)"Timer1", 80 / portTICK_RATE_MS, pdFALSE, (void*) 0, vTimerFunction);
if (xTimer1 != NULL)
// task self-destruction
vTaskDelete( NULL );
So, calling xTimerCreate causes strange error - prefetch exception.
Moving block
into the main function (for example, before vTaskStartScheduler()) makes code working properly.
What’s wrong?
Any ideas, please…
