I have a timer (getTimeUpdateTmr) that sets a flag to initiate a real time clock update every 6 hours.
#define UPDATE_TIME_INTERVAL (6 * 3600 * 1000)
__inline setTimeError_t setRTC_ToNetworkTimeDate(const bool printToUart, bool* validTime)
struct tm *gtime;
wiFiPars.networkBusy = true;
xTimerChangePeriod(getTimeUpdateTmr, UPDATE_TIME_INTERVAL, 50); /* TODO */
If I have an error in the update routine I wish to change the getTimeUpdateTmr’s duration to a shorter value to cause the RTC update to occur more often.
At the start of the RTC update function (setRTC_ToNetworkTimeDate) I set the timer back to 6 Hours; the UPDATE_TIME_INTERVAL.
However the xTimerChangePeriod causes the system to hang in the xTimerGenericCommand.
BaseType_t xTimerGenericCommand( TimerHandle_t xTimer, const BaseType_t xCommandID, const TickType_t xOptionalValue, BaseType_t * const pxHigherPriorityTaskWoken, const TickType_t xTicksToWait )
BaseType_t xReturn = pdFAIL;
DaemonTaskMessage_t xMessage;
configASSERT( xTimer ); <<<< hangs here
/* Send a message to the timer service task to perform a particular action
on a particular timer definition. */
if( xTimerQueue != NULL )
The setRTC_ToNetworkTimeDate is called from a statically defined task. I do not call any functions from interrups apart from notifications and sem’s. The system runs fine without the xTimerChangePeriod included in the build.
WIFI_StatusTypeDef startWiFiSystem()
wiFiTskHandle = xTaskCreateStatic( wiFiTask,
"wifiTask",
STACK_SIZE_WIFI_TASK,
NULL,
PRIO_WI_FI_TASK, /* TODO - Review priorities */
wiFiTaskStack,
&wiFiTskBuffer);
if(wiFiTskHandle == NULL)
return WIFI_XPORT_TASK_FAILED;
rtosTaskStates.wiFiTask = eRunning;
#if(ENABLE_COMMS_TIMEOUT == 1)
return WIFI_OK;
The wiFiTask calls the setRTC_ToNetworkTimeDate when the getTimeUpdateTmr function callback set the flag read by the wiFiTask.
I’m not sure what I am doing wrong, any ideas?
Best regards
Rob
