I am having an issue with xQueueSendBackFromISR. I use it inside a UART interrupt routine to send a message to another task to state that a line is ready to be read. It works for hours and suddenly for any reason, the xQueueSendBackFromISR fails. It does not return pdPASS. The queue is not full. I even reset it when the problem occur but it does not seem to help. The xQueueSendBackFromISR never seem to respond back and always fails thereafter.
When it stops working can you put a break point in the code and step into the function to see what it is doing?
Is your interrupt stack large enough for the line array and to call sprintf() which often uses a lot of stack space?
Can xprintln be called from an interrupt?
A couple of issues that might cause this sort of error.
1) Stack corruption, this ISR uses a LOT of stack for an ISR, since it allocates an 80 byte array. Many ports use the current tasks stack for the ISR, so in this case you need this much extra room in every task’s stack. If one doesn’t have enough, then when you get “lucky” enough to interrupt while that task is active, problems arise.
2) Make very sure that you have interrupt priorities set properly. Most ports only allow ISRs of certain priorities to call FreeRTOS APIs, and an interrupt at a higher level than this can cause corruption that could cause this.
