dcgirish16 wrote on Friday, March 22, 2013:
following code shows the creation of task & queue, posting and receiving of queue.
Task waiting on queue: serialRecvTask
Isr Posting message : UART0_Recv_Interrupt_Handler
Message Queue created: serialRecvQueue
typedef struct _serialRecvQueue
unsigned char cmd;
}SERIAL_RECV_QUEUE;
/////##### Task ‘serialRecvTask’ and queue ‘serialRecvQueue’ are created here in main function.
################################ Main function creating Task and queue #########################################
int main(void)
APP_SHARED_DATA appSharedData;
int i;
initTarget();
//xTaskCreate(ledTask, “NAME”, configMINIMAL_STACK_SIZE, (void *)&appSharedData, mainLED_TASK_PRIORITY + 5, ( xTaskHandle * ) NULL );
// xTaskCreate(serialOutTask, “NAME”, configMINIMAL_STACK_SIZE, (void *)&appSharedData, mainCHECK_TASK_PRIORITY, ( xTaskHandle * ) NULL );
// xTaskCreate(keyTask, “NAME”, configMINIMAL_STACK_SIZE, NULL, mainCHECK_TASK_PRIORITY + 7, ( xTaskHandle * ) NULL );
// xTaskCreate(adcTask, “NAME”, configMINIMAL_STACK_SIZE, (void *)&appSharedData, mainCHECK_TASK_PRIORITY + 6, ( xTaskHandle * ) NULL );
// xTaskCreate(dummyTask, “NAME”, configMINIMAL_STACK_SIZE, (void *)&appSharedData, mainCHECK_TASK_PRIORITY + 4, ( xTaskHandle * ) NULL );
xTaskCreate(serialRecvTask, “NAME”, configMINIMAL_STACK_SIZE, (void *)&appSharedData, mainCHECK_TASK_PRIORITY + 8, ( xTaskHandle * ) NULL );
// xTaskCreate(canMsgProcessTask, “NAME”, configMINIMAL_STACK_SIZE, (void *)&appSharedData, mainCHECK_TASK_PRIORITY + 9, ( xTaskHandle * ) NULL );
// xTaskCreate(canControlTask, “NAME”, configMINIMAL_STACK_SIZE, (void *)&appSharedData, mainCHECK_TASK_PRIORITY + 8, ( xTaskHandle * ) NULL );
/* Create Queue for Serial Input */
serialRecvQueue = xQueueCreate(5, sizeof(SERIAL_RECV_QUEUE));
if(serialRecvQueue == 0)
putstr(“Could NOT create serialRecvQueue”);
putchar(’\n’);
################ Task waiting on Queue #####################################3
void serialRecvTask(void* pvParameters)
SERIAL_RECV_QUEUE recvSerialCmd;
unsigned char levelSensorVal = 0;
unsigned char resistanceVal = 0;
pvParameters = pvParameters;
while(1)
printf(“Serial Recv Task: Waiting on Queue\n”);
//if(xQueueReceive(serialRecvQueue, (void *)&recvSerialCmd, portMAX_DELAY))//If can be taken off as task gets blocked
if(xQueueReceive(serialRecvQueue, (void *)&recvSerialCmd, 1000))//If can be taken off as task gets blocked
printf(“Serial Recv Task: Received Msg=%c\n”, recvSerialCmd.cmd);
#if 0
switch(recvSerialCmd.cmd)
case 0x31:{
printf("%c%c", recvSerialCmd.cmd, levelSensorVal++);
levelSensorVal = levelSensorVal % 253;
break;
case 0x32:{
printf("%c%c", recvSerialCmd.cmd, resistanceVal++);
resistanceVal = resistanceVal % 253;
break;
default:{
printf("%c%c", recvSerialCmd.cmd, 0xFF);
break;
vTaskDelay(10); // May not be required
//################ Interrupt posting Queue Message ##########################/
void UART0_Recv_Interrupt_Handler(void){
unsigned char recvdChar;
SERIAL_RECV_QUEUE recvdMsg;
portBASE_TYPE xHigherPriorityTaskWoken;
recvdChar = U0RBR;
recvdChar = ‘\0’;
recvdMsg.cmd = recvdChar;
if(serialRecvQueue != 0)
//if(xQueueSendToBackFromISR(serialRecvQueue, (void *)&recvdMsg, &xHigherPriorityTaskWoken) != pdPASS)
if(xQueueSendToBackFromISR(serialRecvQueue, (void *)&recvdMsg, pdFALSE) != pdPASS)
putstr(“UART0 ISR: Failed to send Message”);
putchar(’\n’);
// putstr(“UART0 ISR: Message Queued Successfully”);
// putchar(’\n’);
putstr(“UART0 ISR: Not Valid Queue”);
putchar(’\n’);
printf(“Received String : %s\n”, recvdChar);
VICVectAddr = 0; /* Acknowledge Interrupt */
################################################################################33
