I have downloaded FreeRTOS 9.0.0 rc2 because I need to work with the latest FreeRTOS while Atmel ASF only provides FreeRTOS v.7.
However, it’s unclear to me how should I build the samples provided with the FreeRTOS download under Atmel Studio. I only get folder with main.c and other folders that contain AVR32 specific files.
Unfortunately I don’t know how to build this under Atmel Studio and also how to link it with FreeRTOS sources which are in completely different directory and have no relation to demo sources.
Thanks, Hein,
yes, I am working with UC3.
What you suggest is the what I have tried multiple times last year with FreeRTOS v8 and now for the new project I am trying the same thinkg with v9. However, I am getting countless compile errors which I am trying to fix one by one, but every time I am close to zero, the build process seems to progress one step further and I get even more compile errors then. Therefore I don’t see any way how to get rid of all the errors.
Is there any paid support or a person I can pay directly that would do this for me? I am spending too much time upgrading FreeRTOS v7 to v9 in Atmel Studio 7 project instead of doing the development.
I need to have a modified sample of basic FreeRTOS sample from Atmel Studio 7 with FreeRTOS v9 instead of v7…will give it another couple of tries today, but I am willing to pay someone if I have to lose more time than that.
I don’t mind looking at the compiler output and give some hints.
If you want, email me directly to h point tibosch at freertos point org and we’ll get through it after a few emails. I’m not unfamiliar with the UC3A0512.
In return, I would appreciate if you put your DEMO project available for other users.
I am not sure I can really preserve the e.g. portmacro.h from the FreeRTOS/Source/portable/[compiler]/AVR32_UC3 folder of the Atmel ASF because then I am completely missing the BaseType_t definition which is defined in FreeRTOS v9 sources in portmacro.h as:
typedef long BaseType_t;
Are you sure in that case I must preserve all files from FreeRTOS/Source/portable/[compiler]/AVR32_UC3 folder created by Atmel Studio?
Hi, sorry to revive an old thread but the problem in question persist.
I’m also working with AVR32 UC3C and there’s no problem building FreeRTOS v7 provided by ASF.
Building v9 is impossible, though, because the Atmel Framework doesn’t even have the header files (sys/cpu.h, sys/usart.h) referenced from FreeRTOS/portable/GCC/AVR32/AVR32_UC3/port.c.
