timonm wrote on Wednesday, March 11, 2015:
I got a wierd timing problem.
I have two tasks. There is a constant task switch between these two tasks.
I use the cycle counter timer to measure the total length of the task switch. But here is the wierd part.
When i add one line of code, the code is faster, than when i remove the line. How is this possible?
when i add the code. the total cycles is: 4846.
When i remove the line. the total cycles is: 4897.
Below the source code:
/******************************************************************* * Includes *******************************************************************/ #include "FreeRTOS.h" #include "task.h" #include "queue.h" #include "swv.h" /******************************************************************* * Defines *******************************************************************/ #define COUNTER #define MAX_LOOPS 10 #define DEMCR (*((volatile uint32_t *)0xE000EDFC)) #define DWT_CTRL (*(volatile uint32_t *)0xe0001000) #define mainFIRST_TASK_PRIORITY (tskIDLE_PRIORITY + 2) #define mainSECOND_TASK_PRIORITY (tskIDLE_PRIORITY + 2) /******************************************************************* * Types *******************************************************************/ xTaskHandle xHandleFirst; xTaskHandle xHandleSecond; /******************************************************************* * Data *******************************************************************/ uint32_t m_nStart; //DEBUG Stopwatch start cycle counter value uint32_t m_nStop; //DEBUG Stopwatch stop cycle counter value /******************************************************************* * Local Function Prototypes *******************************************************************/ static void prvFirst(void *pvParameters); static void prvSecond(void *pvParameters); int main(void) { /* Enable DWT */ DEMCR |= 0x01000000; /* Enable CPU cycle counter */ DWT_CTRL |= 1; while(1) { xTaskCreate(prvSecond, (const char *) "S", configMINIMAL_STACK_SIZE,NULL, mainSECOND_TASK_PRIORITY, &xHandleSecond); xTaskCreate(prvFirst, (const char *) "F", configMINIMAL_STACK_SIZE,NULL, mainFIRST_TASK_PRIORITY, &xHandleFirst); vTaskStartScheduler(); } } //Task 1 static void prvFirst(void *pvParameters) { while(1) { m_nStart = *((volatile uint32_t *)0xE0001004); // save clockcycle count for(uint32_t count1 = 0; count1 < MAX_LOOPS; count1++) { taskYIELD(); } vTaskDelete(xHandleFirst); } } //task 2 static void prvSecond(void *pvParameters) { while(1) { for (uint32_t count2 = 0; count2 < MAX_LOOPS-1; count2++) { taskYIELD(); } m_nStop = *((volatile uint32_t *)0xE0001004); // save clockcycle count // ADD ONE LINE OF CODE AFTER THIS. THE CODE RUNS FASTER SWV_printnum(m_nStop); SWV_puts("\r\n"); SWV_printnum(m_nStart); SWV_puts("\r\n"); vTaskDelete(xHandleSecond); } }
