aeyes wrote on Sunday, July 04, 2010:
I am working with FreeRTOS for ARM7_LPC2106_GCC. I saw in the startup file a call to vPortYieldProcessor in the SWI interrupt handler. Where is SWI used in FreeRTOS?
davedoors wrote on Sunday, July 04, 2010:
Did you try searching the source directory for SWI?
rtel wrote on Sunday, July 04, 2010:
SWI is called each time taskYIELD() is called, which can be from inside an API function or just called directly by a task.
