Hey guys; hoping someone can help me with, what i believe to be a simple problem, but i’m stumped. i have a working sample that allows me to wake a task from another task via a handle and i would simply like to do the same thing from within an ISR. with the example below, I am able to trigger an interrupt from a task ( lighting the onboard led ), but i cannot get another task ( flash_led ) to run from the triggered ISR? what am i missing? using ESP32 DEV C.
#include <stdio.h>
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/semphr.h"
#include "driver/ledc.h"
#include "esp_err.h"
#include "esp_intr_alloc.h"
#define BLINK_GPIO 2
#define LED_FADE_GIPO 15
#define GIPO_0 18 /// INTTERRUPTOR ( SOURCE PIN )
#define GIPO_1 19
#define INTERUPT_GPIO 25
#define DEBUG_TASK_STAC 2048
#define HEARTBEAT_DELAY 3000
#define HEARTBEAT_PULSE 100
#define HEARTBEAT_FLASH 200
#define NOTIFICATION_PAUSE 1000
#define INTERUPT_DELAY 5000
TaskHandle_t flashHandle = NULL;
TaskHandle_t xHandle;
void task_interuptPing(void *pvParameter) {
gpio_pad_select_gpio(GIPO_0);
gpio_set_direction(GIPO_0, GPIO_MODE_OUTPUT);
TaskHandle_t handle;
//handle = (TaskHandle_t*)pvParameter;
while(1){
gpio_set_level(GIPO_0, 1);
vTaskDelay(HEARTBEAT_PULSE / portTICK_PERIOD_MS);
gpio_set_level(GIPO_0, 0);
vTaskDelay(INTERUPT_DELAY / portTICK_PERIOD_MS);
//vTaskResume((TaskHandle_t*)pvParameter);
//vTaskDelay(INTERUPT_DELAY / portTICK_PERIOD_MS);
void task_flashLED(void *pvParameter) {
gpio_pad_select_gpio(GIPO_1);
gpio_set_direction(GIPO_1, GPIO_MODE_OUTPUT);
while(1){
printf("LED SUSPEND\r\n");
vTaskSuspend(NULL);
gpio_set_level(GIPO_1, 1);
gpio_set_level(GIPO_1, 0);
void handler( void *args ){
BaseType_t xHigherPriorityTaskWoken;
uint32_t ulStatusRegister = 0x00;
handle = (TaskHandle_t*)args;
if (gpio_get_level(BLINK_GPIO)){
gpio_set_level(BLINK_GPIO, 0);
}else{
gpio_set_level(BLINK_GPIO, 1);
xTaskNotifyFromISR(handle, 0, ulStatusRegister,&xHigherPriorityTaskWoken );
///vTaskNotifyGiveFromISR(handle, &xHigherPriorityTaskWoken);
portYIELD_FROM_ISR();
void app_main() {
setvbuf(stdout, NULL, _IONBF, 0); // SECURED BUFF FIX FOR PRINTF
gpio_pad_select_gpio(BLINK_GPIO);
gpio_set_direction(BLINK_GPIO, GPIO_MODE_INPUT_OUTPUT); // SETTING TO READ AND SET?!?!
xTaskCreate( &task_flashLED, "flashLED", DEBUG_TASK_STAC, NULL, 7, &flashHandle);
//xTaskCreate( &task_interuptPing, "Task 1", DEBUG_TASK_STAC, (void*)pcTextForTask1, 1, NULL );
xTaskCreate( &task_interuptPing, "Task 1", DEBUG_TASK_STAC, (void*)flashHandle, 1, NULL );
// INTERRUPTT /////
gpio_config_t gpioConfig;
gpioConfig.pin_bit_mask = GPIO_SEL_25;
gpioConfig.mode = GPIO_MODE_INPUT;
gpioConfig.pull_up_en = GPIO_PULLUP_DISABLE;
gpioConfig.pull_down_en = GPIO_PULLDOWN_ENABLE;
gpioConfig.intr_type = GPIO_INTR_POSEDGE;
gpio_config(&gpioConfig); // config pin 25 for interupts.
gpio_install_isr_service(0);
gpio_isr_handler_add(INTERUPT_GPIO, &handler, (void*)flashHandle);
