I have a task A create a task B. Task B starts a measurement, an ISR wakes it up.
It seems like the ISR calling xTaskNotifyfromISR and portYIELD_FROM_ISR with the handle of task B, actually wakes up task A.
Is this expected? If yes, what terms should I have search for, to find info about this? If no, any idea what might be going on? Task B is not waiting for anything from A.
Possibly, the ISR finishes and tries to wake B up when it is no longer in its vTaskDelay. Still, in that case, B should go on and run its stuff after the loop, and notify A with the new value.
Instead, A wakes up with its notified value at 0, before B has the time to process value and notify A with it.
You are correct. I suppose the original plan was to have a wait instead of a vTaskdelay in the B task, and to terminate it early in case the ISR executed.
I removed the notify from the ISR, unfortunately that made no difference.
sensor_find_task notifies a task, only after the ISR has set a flag to true
I expect:
ISR set the flag
B notices it, exits the while loop, notifies A
A wakes up and prints the value sent together with the notification from B
I observe, in that order:
ISR sets the flag (I have a short printf in there)
A wakes up with notification value 0
B comes out of the while loop, has correct value before trying to notify A
Is there a way I can see, in A, where the waking notification origins from?
EDIT:
In this case, since you made me notice I don’t need the notification from ISR, I don’t need the ISR at all, I can just read the GPIO level in the task. Still, I would like to understand what is causing the ISR to wake task A. I also have a global gpio ISR, set with gpio_set_irq_enabled_with_callback, but this ISR I set raw with gpio_add_raw_irq_handler.
Calling printf from ISR is not a good idea. Please remove that.
It may be a memory corruption. One way to debug is to put a databreakpoint on the notification state variable of the A’s TCB and see who is updating it.
You’re right. In this case, this is a single character without a flush, and was added solely for debugging. The behavior does not change with or without the print, and it will go away once I understand what is going on.
Good suggestion. Unfortunately, my gdb and rp2040 does not seem to support watchpoints. I don’t know if that is fixable, or if the HW just isn’t there.
Anyway, I just found out that another ISR notifies the same task. I didn’t expect this ISR to trigger, so I have more digging to do for that, but it’s another issue.
Thanks for your help, not least confirming that what I was seeing was unexpected (I have been working with Contiki in the past, where waking a thread up had to go through a possible parent thread. This is why I found this suspicious, maybe it’s some light PTSD ).
