zhoubowei008 wrote on Friday, October 11, 2019:
hi please help, not sure why only task2 is excuted.
I am using STM32G071RB
Thank you
#include “stm32g0xx.h”
#include “stm32g0xx_nucleo.h”
#include “FreeRTOSConfig.h”
#include “task.h”
#include <stdio.h>
#include <stdint.h>
TaskHandle_t xTaskHandle1 = NULL;
TaskHandle_t xTaskHandle2 = NULL;
//task function prototypes
void vTask1_handler(void *params);
void vTask2_handler(void *params);
// used for semihosting
extern void initialise_monitor_handles();
int main(void)
// printf(“first code\n”);
printf(“System clock is %d\n”,SystemCoreClock);
// turn off PLL and HSE, turn ON HSI
HAL_RCC_DeInit();
// update system clock variables
SystemCoreClockUpdate();
// Create two tasks
xTaskCreate(vTask1_handler,“Task-1”,configMINIMAL_STACK_SIZE,NULL,1,&xTaskHandle1);
xTaskCreate(vTask2_handler,“Task-2”,configMINIMAL_STACK_SIZE,NULL,1,&xTaskHandle2);
//Create scheduler to run tasks
vTaskStartScheduler();
for(;;);
while(1)
printf(“task1 is running\n”);
// printf(“task1”);
while(1)
printf(“task2 is running\n”);
// printf(“task2”);
my FreeTTOSConfig.h
#ifndef FREERTOS_CONFIG_H
#define FREERTOS_CONFIG_H
- Application specific definitions.
- These definitions should be adjusted for your particular hardware and
- application requirements.
- THESE PARAMETERS ARE DESCRIBED WITHIN THE ‘CONFIGURATION’ SECTION OF THE
- FreeRTOS API DOCUMENTATION AVAILABLE ON THE FreeRTOS.org WEB SITE.
- See http://www.freertos.org/a00110.html
extern uint32_t SystemCoreClock;
#define configUSE_IDLE_HOOK 0
#define configUSE_TICK_HOOK 0
//#define configCPU_CLOCK_HZ ( ( unsigned long ) 16000000 )
#define configCPU_CLOCK_HZ ( SystemCoreClock )
#define configTICK_RATE_HZ ( ( TickType_t ) 1000 )
#define configMAX_PRIORITIES ( 5 )
#define configMINIMAL_STACK_SIZE ( ( unsigned short ) 120 )
//#define configTOTAL_HEAP_SIZE ( ( size_t ) ( 16 * 1024 ) )
#define configTOTAL_HEAP_SIZE ( ( size_t ) ( 10 * 1024 ) )
#define configMAX_TASK_NAME_LEN ( 16 )
/* Co-routine definitions. */
#define configMAX_CO_ROUTINE_PRIORITIES ( 2 )
#define configUSE_MUTEXES 1
#define configUSE_COUNTING_SEMAPHORES 1
#define configUSE_ALTERNATIVE_API 0
// to define the stack overflow check mechanism
#define configCHECK_FOR_STACK_OVERFLOW 0
#define configUSE_RECURSIVE_MUTEXES 1
#define configQUEUE_REGISTRY_SIZE 0
#define configGENERATE_RUN_TIME_STATS 0
#define INCLUDE_vTaskPrioritySet 1
#define INCLUDE_uxTaskPriorityGet 1
#define INCLUDE_vTaskDelete 1
#define INCLUDE_vTaskCleanUpResources 0
#define INCLUDE_vTaskDelayUntil 1
#define INCLUDE_vTaskDelay 1
/* This is the raw value as per the Cortex-M3 NVIC. Values can be 255
(lowest) to 0 (1?) (highest). /
#define configKERNEL_INTERRUPT_PRIORITY 255
/ !!! configMAX_SYSCALL_INTERRUPT_PRIORITY must not be set to zero !!!
See http://www.FreeRTOS.org/RTOS-Cortex-M3-M4.html. /
#define configMAX_SYSCALL_INTERRUPT_PRIORITY 191 / equivalent to 0xb0, or priority 11. */
/* This is the value being used as per the ST library which permits 16
priority values, 0 to 15. This must correspond to the
configKERNEL_INTERRUPT_PRIORITY setting. Here 15 corresponds to the lowest
NVIC value of 255. */
#define configLIBRARY_KERNEL_INTERRUPT_PRIORITY 15
- UART configuration.
#define configCOM0_RX_BUFFER_LENGTH 128
#define configCOM0_TX_BUFFER_LENGTH 128
#define configCOM1_RX_BUFFER_LENGTH 128
#define configCOM1_TX_BUFFER_LENGTH 128
