Hi all,
I using FreeRTOS V9.0.0 on STM32F4 microcontroller for TFTP server.
The vTaskDelay never return when it is call after a blocking operation (e.g. after xQueueGenericReceive())
In details, the TFTP listening task is:
void TFTPserverlistening(void pArgs)
// Create a socket
// Bind it to the desired port and protocol
// Neverending loop
while (1)
vTaskDelay(1000); //this works
/ wait for a connection request (wait a file to upload) - lwip stack /
n = recvfrom(sd, &args->request, TFTPMAXMSGLEN, 0, (struct sockaddr )&args->from, (socklent )&fromlen);
vTaskDelay(1000); //this dosen’t work - NO RETURN
where the recvfrom is define as lwip_recvfrom.
The lwip_recvfrom is part of the lwipstack which use the xQueueGenericReceive in order to wait forever a incoming message.
Similar problem can be obtain calling tow time the vTaskDelay with very long dela:
vTaskDelay(10000); //this works, yep for 10 seconds it works
Debugging the vTaskDelay and using the trace data log (with keil) I don’t have see any problem,
Possibilities for vTaskDelay() never returning would be:
The task that called vTaskDelay() is being starved out by higher
priority tasks that never block.
The tick interrupt is not running (when the issue occurs, inspect the
xTickCount variable or set a break point in the SysTick_Handler() ISR
function or xTaskIncrementTick function to see if the tick count is
still incrementing).
You have an old fashioned data corruption that has messed up the
linked list from which the task is being referenced. Do you have
configASSERT() defined? Do you have stack overflow protection turned on?
If everything works fine until recvfrom() is called then have a good
look at that function to make sure there is no way it could exit with
interrupts disabled, or from inside a critical section.
I don’t get your seggestion. Do you think it could be a problem related to priority? The TFTPserverlistening task is created in main function with priority = 6.
During vTaskDelay running (never exiting) the system is alive (it is not in halt). The system tick Timer is runinng and the SysTick_Handler(void) routine is correctly executed (xTickCount is incrementing). Even the vApplicationIdleHook is running.
Where I can check if the configASSERT() and stack overflow protection are defined?
Yes, I am sure that the recvfrom() exit with all interrupts enable.
Thanks
m
I thought that was a possibility, but as you say that
vApplicationIdleHook() is running it seems that is not the case.
