reny09 wrote on Tuesday, June 03, 2008:
Hi
I´m using FreeRtos 5.0.0 and I have two tasks in a MSP430 with IAR. One blocked for ever because it temporaly empty and in another if I try the following
const portTickType xDelay = 5;
for (;
LedToggle();
vTaskDelay( xDelay );
The led only Blink if I use #define configUSE_PREEMPTION 0, if it is set it doesn´t work. If I use VTaskDelayUntil it doesn´t work with both configurations. The microcontroller is working perfectly because I´m sending and receiving data through a radio using interrupts.
What I could be doing wrong? The full configuration is this one.
#define configUSE_IDLE_HOOK 0
#define configUSE_TICK_HOOK 0
#define configCPU_CLOCK_HZ ( ( unsigned portLONG ) 7372800 ) /* Clock setup from main.c in the demo application. */
#define configTICK_RATE_HZ ( ( portTickType ) 256 )
#define configMAX_PRIORITIES ( ( unsigned portBASE_TYPE ) 5 )
#define configMINIMAL_STACK_SIZE ( ( unsigned portSHORT ) 100 )
#define configTOTAL_HEAP_SIZE ( ( size_t ) ( 4000 ) )
#define configMAX_TASK_NAME_LEN ( 8 )
#define configUSE_TRACE_FACILITY 0
#define configUSE_16_BIT_TICKS 1
#define configUSE_MUTEXES 1
