vTaskCreatePinnedToCore Synchronous Mode
Using ESP32 Gateway board I need to use both threads and create tasks in synchronous mode on both threads. How can I do that? Basically I want to create new tasks that will run after the previous task is ended.
I created a small Sketch to see the expected result:
#include "Arduino.h"
void FreertosTask1Dispatch(int Crt);
void FreertosTask1Code(void * pvParamaters);
TaskHandle_t FreertosTask1;
void FreertosTask1Dispatch(int Crt) {
    Serial.println(Crt);
    Serial.println(" - freertos dispatch function started.");
    xTaskCreatePinnedToCore(
      FreertosTask1Code,   /* Function to implement the task */
      "FreertosTask1Code", /* Name of the task */
      10000,      /* Stack size in words */
      (void*)&Crt,       /* Task input parameter */
      1,          /* Priority of the task */
      &FreertosTask1,       /* Task handle. */
    0);  /* Core where the task should run */
void FreertosTask1Code(void * pvParamaters) {
    int Crt = *((int*)pvParamaters);
    Serial.print(Crt);
    Serial.println("- before delay.");
    delay(6000);
    Serial.print(Crt);
    Serial.println("- after delay.");
    vTaskDelete(NULL);
void Synchronous(int Crt)
    Serial.print(Crt);
    delay(6000);
    Serial.print(Crt);
void setup() {
  Serial.begin(256000);
  Serial.println("Tasks on core 0");
  for (int Crt = 0; Crt <= 15; Crt++) {
    FreertosTask1Dispatch(Crt);
  delay(10000);
  //Expected result but using vTaskCreatePinnedToCore. How can I do that using vTaskCreatePinnedToCore?
  Serial.println("Synchronous.");
    Synchronous(Crt);
  return;
void loop() {
  return;
Thanks
That would be a really unusual thing to want to do. Generally when I see people creating and deleting tasks on the fly like this there is a simpler way of doing what they want to do. Can you explain the outcome you want, rather than the implementation you are thinking of to achieve it?
