benedictheyer wrote on Friday, July 08, 2011:
Hello!
I am trying to get the officially supoprted demo working on my SAM9XE dev board.
I am following this tutorial:
http://www.freertos.org/index.html?http://www.freertos.org/ARM9-AT91SAM9-RTOS-Demo.html
First, I stumbled upon this statement:
A loopback connector is required on UART0 for this mechanism to operate (simply connect pins 2 and 3 together on connector J20).
There is no J20 connector, so which connection is meant?
Okay, now my main problem:
When I compile the demo I get 0 errors and 4 warnings (conversion warnings). When I try to flash my board (using my Atmel SAM ICE programmer) in ARM mode, the program hangs and is not responsive anymore. When I try it in THUMB mode, I get 2 errors and 3 warnings. This is the log:
Fri Jul 08, 2011 15:15:07: Loaded macro file: C:\Users\Benedict\Documents\IAR Embedded Workbench\FreeRTOS\FreeRTOS\Demo\ARM9_AT91SAM9XE_IAR\ewp\at91sam9xe-ek-sdram.mac
Fri Jul 08, 2011 15:15:07: JLINK command: ProjectFile = C:\Users\Benedict\Documents\IAR Embedded Workbench\FreeRTOS\FreeRTOS\Demo\ARM9_AT91SAM9XE_IAR\ewp\settings\
at91sam9xe-ek_AT91SAM9XE512_SDRAM_THUMB.jlink, return = 0
Fri Jul 08, 2011 15:15:07: JLINK command: device = AT91SAM9XE512, return = 0
Fri Jul 08, 2011 15:15:07: DLL version: V4.26a, compiled Apr 28 2011 09:21:00
Fri Jul 08, 2011 15:15:07: Firmware: J-Link ARM V8 compiled Apr 27 2011 20:42:35
Fri Jul 08, 2011 15:15:07: JTAG speed is using adaptive clocking (RTCK signal)
Fri Jul 08, 2011 15:15:07: Initial reset was performed
Fri Jul 08, 2011 15:15:07: TotalIRLen = 4, IRPrint = 0x01
Fri Jul 08, 2011 15:15:07: CP15.0.0: 0x41069265: ARM, Architecure 5TEJ
Fri Jul 08, 2011 15:15:07: CP15.0.1: 0x1D112152: ICache: 16kB (4*128*32), DCache: 8kB (4*64*32)
Fri Jul 08, 2011 15:15:07: Cache type: Separate, Write-back, Format C (WT supported)
Fri Jul 08, 2011 15:15:07: Found 1 JTAG device, Total IRLen = 4:
Fri Jul 08, 2011 15:15:07: #0 Id: 0x0792603F, IRLen: 4, IRPrint: 0x1 ARM926EJ-S Core
Fri Jul 08, 2011 15:15:07: J-Link found 1 JTAG device(s). ARM core Id: 792603F ARM9
Fri Jul 08, 2011 15:15:07: Device at TAP0 selected
Fri Jul 08, 2011 15:15:07: J-Link: ARM9 CP15 Settings changed: 50078 from 78, MMU Off, ICache Off, DCache Off
Fri Jul 08, 2011 15:15:07: ------------------------------ execUserPreload ---------------------------------
Fri Jul 08, 2011 15:15:07: Hardware reset with strategy 0 was performed
Fri Jul 08, 2011 15:15:07: Macro __sleep( microseconds ) is obsolete, use __delay( milliseconds ) instead.
Fri Jul 08, 2011 15:15:07: C:\Users\Benedict\Documents\IAR Embedded Workbench\FreeRTOS\FreeRTOS\Demo\ARM9_AT91SAM9XE_IAR\ewp\at91sam9xe-ek-sdram.mac(207,12): Error: Operation error.
Fri Jul 08, 2011 15:15:07: Error while calling macro execUserPreload
Fri Jul 08, 2011 15:15:10: 95920 bytes downloaded and verified (31.60 Kbytes/sec)
Fri Jul 08, 2011 15:15:10: Warning:
Verify error at address 0x20000000, target byte: 0xFF, byte in file: 0x30
Verify error at address 0x20000001, target byte: 0xFF, byte in file: 0xF0
Verify error at address 0x20000002, target byte: 0xFF, byte in file: 0x9F
Verify error at address 0x20000003, target byte: 0xFF, byte in file: 0xE5
Verify error at address 0x20000004, target byte: 0xFF, byte in file: 0x30
Verify error at address 0x20000005, target byte: 0xFF, byte in file: 0x00
Verify error at address 0x20000006, target byte: 0xFF, byte in file: 0x9F
Verify error at address 0x20000007, target byte: 0xFF, byte in file: 0xE5
Verify error at address 0x20000008, target byte: 0xFF, byte in file: 0x30
Verify error at address 0x20000009, target byte: 0xFF, byte in file: 0x40
Verify error at address 0x2000000A, target byte: 0xFF, byte in file: 0x9F
Verify error at address 0x2000000B, target byte: 0xFF, byte in file: 0xE5
Verify error at address 0x2000000C, target byte: 0xFF, byte in file: 0x04
Verify error at address 0x2000000D, target byte: 0xFF, byte in file: 0xD0
Verify error at address 0x2000000E, target byte: 0xFF, byte in file: 0xA0
Verify error at address 0x2000000F, target byte: 0xFF, byte in file: 0xE1
Verify error at address 0x20000010, target byte: 0xFF, byte in file: 0x0F
Verify error at address 0x20000011, target byte: 0xFF, byte in file: 0xE0
Verify error at address 0x20000012, target byte: 0xFF, byte in file: 0xA0
Verify error at address 0x20000013, target byte: 0xFF, byte in file: 0xE1
Verify error at address 0x20000014, target byte: 0xFF, byte in file: 0x10
Verify error at address 0x20000016, target byte: 0xFF, byte in file: 0x2F
Verify error at address 0x20000017, target byte: 0xFF, byte in file: 0xE1
Verify error at address 0x20000018, target byte: 0xFF, byte in file: 0xD2
Verify error at address 0x20000019, target byte: 0xFF, byte in file: 0xF0
Verify error at address 0x2000001A, target byte: 0xFF, byte in file: 0x21
Verify error at address 0x2000001B, target byte: 0xFF, byte in file: 0xE3
Verify error at address 0x2000001C, target byte: 0xFF, byte in file: 0x20
Verify error at address 0x2000001D, target byte: 0xFF, byte in file: 0xD0
Verify error at address 0x2000001E, target byte: 0xFF, byte in file: 0x9F
Verify error at address 0x2000001F, target byte: 0xFF, byte in file: 0xE5
Verify error at address 0x20000020, target byte: 0xFF, byte in file: 0x53
Verify error at address 0x20000021, target byte: 0xFF, byte in file: 0xF0
Verify error at address 0x20000022, target byte: 0xFF, byte in file: 0x21
Verify error at address 0x20000023, target byte: 0xFF, byte in file: 0xE3
Verify error at address 0x20000024, target byte: 0xFF, byte in file: 0x14
Verify error at address 0x20000025, target byte: 0xFF, byte in file: 0xD0
Verify error at address 0x20000026, target byte: 0xFF, byte in file: 0x9F
Verify error at address 0x20000027, target byte: 0xFF, byte in file: 0xE5
Verify error at address 0x20000028, target byte: 0xFF, byte in file: 0x18
Verify error at address 0x20000029, target byte: 0xFF, byte in file: 0x00
Verify error at address 0x2000002A, target byte: 0xFF, byte in file: 0x9F
Verify error at address 0x2000002B, target byte: 0xFF, byte in file: 0xE5
Verify error at address 0x2000002C, target byte: 0xFF, byte in file: 0x0F
Verify error at address 0x2000002D, target byte: 0xFF, byte in file: 0xE0
Verify error at address 0x2000002E, target byte: 0xFF, byte in file: 0xA0
Verify error at address 0x2000002F, target byte: 0xFF, byte in file: 0xE1
Verify error at address 0x20000030, target byte: 0xFF, byte in file: 0x10
Verify error at address 0x20000032, target byte: 0xFF, byte in file: 0x2F
Verify error at address 0x20000033, target byte: 0xFF, byte in file: 0xE1
Verify error at address 0x20000034, target byte: 0xFF, byte in file: 0xFE
Verify error at address 0x20000037, target byte: 0xFF, byte in file: 0xEA
Verify error at address 0x20000038, target byte: 0xFF, byte in file: 0x04
Verify error at address 0x20000039, target byte: 0xFF, byte in file: 0x00
Verify error at address 0x2000003A, target byte: 0xFF, byte in file: 0x00
Verify error at address 0x2000003B, target byte: 0xFF, byte in file: 0x20
Verify error at address 0x2000003C, target byte: 0xFF, byte in file: 0x05
Verify error at address 0x2000003D, target byte: 0xFF, byte in file: 0x5A
Verify error at address 0x2000003E, target byte: 0xFF, byte in file: 0x00
Verify error at address 0x2000003F, target byte: 0xFF, byte in file: 0x20
Verify error at address 0x20000040, target byte: 0xFF, byte in file: 0x48
Verify error at address 0x20000041, target byte: 0xFF, byte in file: 0x70
Verify error at address 0x20000042, target byte: 0xFF, byte in file: 0x01
Verify error at address 0x20000043, target byte: 0xFF, byte in file: 0x20
Verify error at address 0x20000044, target byte: 0xFF, byte in file: 0xA8
Verify error at address 0x20000045, target byte: 0xFF, byte in file: 0x70
Verify error at address 0x20000046, target byte: 0xFF, byte in file: 0x01
Verify error at address 0x20000047, target byte: 0xFF, byte in file: 0x20
Verify error at address 0x20000048, target byte: 0xFF, byte in file: 0xD0
Verify error at address 0x20000049, target byte: 0xFF, byte in file: 0x5C
Verify error at address 0x2000004A, target byte: 0xFF, byte in file: 0x00
Verify error at address 0x2000004B, target byte: 0xFF, byte in file: 0x20
Verify error at address 0x20000100, target byte: 0xFF, byte in file: 0x18
Verify error at address 0x20000101, target byte: 0xFF, byte in file: 0x48
Verify error at address 0x20000102, target byte: 0xFF, byte in file: 0x01
Verify error at address 0x20000103, target byte: 0xFF, byte in file: 0x68
Verify error at address 0x20000104, target byte: 0xFF, byte in file: 0x00
Verify error at address 0x20000105, target byte: 0xFF, byte in file: 0x29
Verify error at address 0x20000106, target byte: 0xFF, byte in file: 0x0E
Verify error at address 0x20000107, target byte: 0xFF, byte in file: 0xD1
Verify error at address 0x20000108, target byte: 0xFF, byte in file: 0x80
Verify error at address 0x20000109, target byte: 0xFF, byte in file: 0x21
Verify error at address 0x2000010A, target byte: 0xFF, byte in file: 0x49
Verify error at address 0x2000010B, target byte: 0xFF, byte in file: 0x02
Verify error at address 0x2000010C, target byte: 0xFF, byte in file: 0x81
Verify error at address 0x2000010D, target byte: 0xFF, byte in file: 0x60
Verify error at address 0x2000010E, target byte: 0xFF, byte in file: 0x09
Verify error at address 0x2000010F, target byte: 0xFF, byte in file: 0x09
Verify error at address 0x20000110, target byte: 0xFF, byte in file: 0x41
Verify error at address 0x20000111, target byte: 0xFF, byte in file: 0x60
Verify error at address 0x20000112, target byte: 0xFF, byte in file: 0x00
Verify error at address 0x20000113, target byte: 0xFF, byte in file: 0x21
Verify error at address 0x20000114, target byte: 0xFF, byte in file: 0xC9
Verify error at address 0x20000115, target byte: 0xFF, byte in file: 0x43
Verify error at address 0x20000116, target byte: 0xFF, byte in file: 0xC1
Verify error at address 0x20000117, target byte: 0xFF, byte in file: 0x60
Verify error at address 0x20000118, target byte: 0xFF, byte in file: 0x01
Verify error at address 0x20000119, target byte: 0xFF, byte in file: 0x61
Verify error at address 0x2000011A, target byte: 0xFF, byte in file: 0x13
Verify error at address 0x2000011B, target byte: 0xFF, byte in file: 0x4A
Verify error at address 0x2000011C, target byte: 0xFF, byte in file: 0x04
Verify error at address 0x2000011D, target byte: 0xFF, byte in file: 0x21
Verify error at address 0x2000011E, target byte: 0xFF, byte in file: 0x41
Verify error at address 0x2000011F, target byte: 0xFF, byte in file: 0x61
Verify error at address 0x20000120, target byte: 0xFF, byte in file: 0x11
Verify error at address 0x20000121, target byte: 0xFF, byte in file: 0x60
Verify error at address 0x20000122, target byte: 0xFF, byte in file: 0x12
Verify error at address 0x20000123, target byte: 0xFF, byte in file: 0x49
Verify error at address 0x20000124, target byte: 0xFF, byte in file: 0x01
Verify error at address 0x20000125, target byte: 0xFF, byte in file: 0x60
Verify error at address 0x20000126, target byte: 0xFF, byte in file: 0x01
Verify error at address 0x20000127, target byte: 0xFF, byte in file: 0x20
Verify error at address 0x20000128, target byte: 0xFF, byte in file: 0x70
Verify error at address 0x20000129, target byte: 0xFF, byte in file: 0x47
Verify error at address 0x2000012A, target byte: 0xFF, byte in file: 0x30
Verify error at address 0x2000012B, target byte: 0xFF, byte in file: 0xB4
Verify error at address 0x2000012C, target byte: 0xFF, byte in file: 0x0C
Verify error at address 0x2000012D, target byte: 0xFF, byte in file: 0x00
Verify error at address 0x2000012E, target byte: 0xFF, byte in file: 0x07
Verify error at address 0x2000012F, target byte: 0xFF, byte in file: 0x23
Verify error at address 0x20000130, target byte: 0xFF, byte in file: 0x08
Verify error at address 0x20000131, target byte: 0xFF, byte in file: 0x34
Verify error at address 0x20000132, target byte: 0xFF, byte in file: 0x1C
Verify error at address 0x20000133, target byte: 0xFF, byte in file: 0x42
Verify error at address 0x20000134, target byte: 0xFF, byte in file: 0x01
Verify error at address 0x20000135, target byte: 0xFF, byte in file: 0xD1
Verify error at address 0x20000136, target byte: 0xFF, byte in file: 0x00
Verify error at address 0x20000137, target byte: 0xFF, byte in file: 0x23
Verify error at address 0x20000138, target byte: 0xFF, byte in file: 0x04
Verify error at address 0x20000139, target byte: 0xFF, byte in file: 0xE0
Verify error at address 0x2000013A, target byte: 0xFF, byte in file: 0x0D
Verify error at address 0x2000013B, target byte: 0xFF, byte in file: 0x00
Verify error at address 0x2000013C, target byte: 0xFF, byte in file: 0x08
Verify error at address 0x2000013D, target byte: 0xFF, byte in file: 0x24
Verify error at address 0x2000013E, target byte: 0xFF, byte in file: 0x08
Verify error at address 0x2000013F, target byte: 0xFF, byte in file: 0x35
Verify error at address 0x20000140, target byte: 0xFF, byte in file: 0x64
Verify error at address 0x20000141, target byte: 0xFF, byte in file: 0x1B
Verify error at address 0x20000142, target byte: 0xFF, byte in file: 0x23
Verify error at address 0x20000143, target byte: 0xFF, byte in file: 0x40
Verify error at address 0x20000144, target byte: 0xFF, byte in file: 0xC9
Verify error at address 0x20000145, target byte: 0xFF, byte in file: 0x18
Verify error at address 0x20000146, target byte: 0xFF, byte in file: 0xD2
Verify error at address 0x20000147, target byte: 0xFF, byte in file: 0x1A
Verify error at address 0x20000148, target byte: 0xFF, byte in file: 0x81
Verify error at address 0x20000149, target byte: 0xFF, byte in file: 0x61
Verify error at address 0x2000014A, target byte: 0xFF, byte in file: 0x01
Verify error at address 0x2000014B, target byte: 0xFF, byte in file: 0x23
Verify error at address 0x2000014C, target byte: 0xFF, byte in file: 0xC2
Verify error at address 0x2000014D, target byte: 0xFF, byte in file: 0x60
Verify error at address 0x2000014E, target byte: 0xFF, byte in file: 0x13
Verify error at address 0x2000014F, target byte: 0xFF, byte in file: 0x43
Verify error at address 0x20000150, target byte: 0xFF, byte in file: 0x4B
Verify error at address 0x20000151, target byte: 0xFF, byte in file: 0x60
Verify error at address 0x20000152, target byte: 0xFF, byte in file: 0x89
Verify error at address 0x20000153, target byte: 0xFF, byte in file: 0x18
Verify error at address 0x20000154, target byte: 0xFF, byte in file: 0x28
Verify error at address 0x20000155, target byte: 0xFF, byte in file: 0x22
Verify error at address 0x20000156, target byte: 0xFF, byte in file: 0x4A
Verify error at address 0x20000157, target byte: 0xFF, byte in file: 0x60
Verify error at address 0x20000158, target byte: 0xFF, byte in file: 0x02
Verify error at address 0x20000159, target byte: 0xFF, byte in file: 0x49
Verify error at address 0x2000015A, target byte: 0xFF, byte in file: 0x09
Verify error at address 0x2000015B, target byte: 0xFF, byte in file: 0x69
Verify error at address 0x2000015C, target byte: 0xFF, byte in file: 0xC1
Verify error at address 0x2000015D, target byte: 0xFF, byte in file: 0x61
Verify error at address 0x2000015E, target byte: 0xFF, byte in file: 0x30
Verify error at address 0x2000015F, target byte: 0xFF, byte in file: 0xBC
Verify error at address 0x20000160, target byte: 0xFF, byte in file: 0x70
Verify error at address 0x20000161, target byte: 0xFF, byte in file: 0x47
Verify error at address 0x20000162, target byte: 0xFF, byte in file: 0x00
Verify error at address 0x20000163, target byte: 0xFF, byte in file: 0x00
Verify error at address 0x20000164, target byte: 0xFF, byte in file: 0x88
Verify error at address 0x20000165, target byte: 0xFF, byte in file: 0x75
Verify error at address 0x20000166, target byte: 0xFF, byte in file: 0x01
Verify error at address 0x20000167, target byte: 0xFF, byte in file: 0x20
Verify error at address 0x20000168, target byte: 0xFF, byte in file: 0x40
Verify error at address 0x20000169, target byte: 0xFF, byte in file: 0x73
Verify error at address 0x2000016A, target byte: 0xFF, byte in file: 0x01
Verify error at address 0x2000016B, target byte: 0xFF, byte in file: 0x20
Verify error at address 0x2000016C, target byte: 0xFF, byte in file: 0x68
Verify error at address 0x2000016D, target byte: 0xFF, byte in file: 0x59
Verify error at address 0x2000016E, target byte: 0xFF, byte in file: 0x88
Verify error at address 0x2000016F, target byte: 0xFF, byte in file: 0x3C
Verify error at address 0x20000170, target byte: 0xFF, byte in file: 0xF0
Verify error at address 0x20000171, target byte: 0xFF, byte in file: 0xB5
Verify error at address 0x20000172, target byte: 0xFF, byte in file: 0x0D
Verify error at address 0x20000173, target byte: 0xFF, byte in file: 0x00
Verify error at address 0x20000174, target byte: 0xFF, byte in file: 0x07
Verify error at address 0x20000175, target byte: 0xFF, byte in file: 0x24
Verify error at address 0x20000176, target byte: 0xFF, byte in file: 0x08
Verify error at address 0x20000177, target byte: 0xFF, byte in file: 0x35
Verify error at address 0x20000178, target byte: 0xFF, byte in file: 0x83
Verify error at address 0x20000179, target byte: 0xFF, byte in file: 0xB0
Verify error at address 0x2000017A, target byte: 0xFF, byte in file: 0x25
Verify error at address 0x2000017B, target byte: 0xFF, byte in file: 0x42
Verify error at address 0x2000017C, target byte: 0xFF, byte in file: 0x01
Verify error at address 0x2000017D, target byte: 0xFF, byte in file: 0xD1
Verify error at address 0x2000017E, target byte: 0xFF, byte in file: 0x00
Verify error at address 0x2000017F, target byte: 0xFF, byte in file: 0x25
Verify error at address 0x20000180, target byte: 0xFF, byte in file: 0x04
Fri Jul 08, 2011 15:15:10: Warning: Too many verify errors, only the first 200 are displayed
Fri Jul 08, 2011 15:15:13: Warning: There were warnings during download, see Log Window
Fri Jul 08, 2011 15:15:13: Loaded debugee: C:\Users\Benedict\Documents\IAR Embedded Workbench\FreeRTOS\FreeRTOS\Demo\ARM9_AT91SAM9XE_IAR\ewp\AT91SAM9XE512_SDRAM_THUMB\Exe\
at91sam9xe512_sdram.out
Fri Jul 08, 2011 15:15:13: Target reset
Fri Jul 08, 2011 15:15:13: ------------------------------ execUserReset ---------------------------------
Fri Jul 08, 2011 15:15:13: ----- AT91C_MATRIX_MRCR : 0x00000003
Fri Jul 08, 2011 15:15:13: ------------------------------- The Remap is done -----------------------------------
Fri Jul 08, 2011 15:15:13: Macro __sleep( microseconds ) is obsolete, use __delay( milliseconds ) instead.
Fri Jul 08, 2011 15:15:13: C:\Users\Benedict\Documents\IAR Embedded Workbench\FreeRTOS\FreeRTOS\Demo\ARM9_AT91SAM9XE_IAR\ewp\at91sam9xe-ek-sdram.mac(207,12): Error: Operation error.
Fri Jul 08, 2011 15:15:13: Error while calling macro execUserReset
Fri Jul 08, 2011 15:15:13: There were 2 errors and 3 warnings during the initialization of the debugging session.
Can anybody giure this out? My board works fine with other programs so I don’t think that it is damaged…
PS: Sorry if something similar has already been answered I did use the board’s search function for half an hour but did not find anything suitable.
Kind regards
Benedict
