AT91SAM7S with IAR tools
felipecpc wrote on Thursday, November 19, 2009:
Hi guys ,
I’m newbie with freertos and i need some help.
I just received a Atmel board AT91SAM7S-EK with jlink and IAR tools, and now i’m trying to get the demo app running on my board …
The project compiled OK , but when i clicked to download and debug, i’ m receiveing a message that notice warnings while generating flash loader.
I clicked OK , and after that another message:
Programming failed @ address 0x00100100
So , after that , it seems to be loaded , but when i clicked Go, the demo app didn’t work .
here my debug log :
    Thu Nov 19 14:32:41 2009: Flash download warning: 64 out of 64 bytes from data record CODE: will not be flashed
    Thu Nov 19 14:32:41 2009: Flash download warning: 13736 out of 13736 bytes from data record CODE: will not be flashed
    Thu Nov 19 14:32:41 2009: There were warnings while generating flash loader input.
    See the Debug Log window for details.
    Thu Nov 19 14:34:22 2009: Skipping flash loading pass because there is no data in the designated range: 0x100000-0x110000.
        Thu Nov 19 14:34:22 2009: Downloaded C:\Documents and Settings\Felipe\Desktop\FreeRTOSV6.0.0\FreeRTOS\Demo\ARM7_AT91SAM7S64_IAR\Flash_Debug\Exe\rtosdemo.out to flash memory.
    Thu Nov 19 14:34:22 2009: Loaded macro file: C:\Documents and Settings\Felipe\Desktop\FreeRTOSV6.0.0\FreeRTOS\Demo\ARM7_AT91SAM7S64_IAR\resource\SAM7.mac
    Thu Nov 19 14:34:23 2009: DLL version: V4.8l, compiled Sep 17 2009 09:41:55
    Thu Nov 19 14:34:23 2009: Firmware: J-Link ARM V7 compiled Jun 30 2009 11:05:27
    Thu Nov 19 14:34:23 2009: JTAG speed is initially set to: 32 kHz
    Thu Nov 19 14:34:23 2009: Initial reset was performed
    Thu Nov 19 14:34:23 2009: TotalIRLen = 4, IRPrint = 0x01
    Thu Nov 19 14:34:23 2009: Found 1 JTAG device, Total IRLen = 4:
    Thu Nov 19 14:34:23 2009:  #0 Id: 0x3F0F0F0F, IRLen:  4, IRPrint: 0x1 ARM7TDMI Core
    Thu Nov 19 14:34:23 2009: J-Link found 1 JTAG device(s). ARM core Id: 3F0F0F0F ARM7
    Thu Nov 19 14:34:23 2009: Device at TAP0 selected
    Thu Nov 19 14:34:23 2009: JLINK command: ProjectFile = C:\Documents and Settings\Felipe\Desktop\FreeRTOSV6.0.0\FreeRTOS\Demo\ARM7_AT91SAM7S64_IAR\settings\rtosdemo_Flash Debug.jlink,
    return = 0
    Thu Nov 19 14:34:23 2009: JLINK command: device = AT91SAM7S64, return = 0
    Thu Nov 19 14:34:24 2009: --------------------- The Remap is NOT ---------------------------
    Thu Nov 19 14:34:24 2009:  --------------------------- Chip ID   0x270D0940
    Thu Nov 19 14:34:24 2009:  --------------------------- Extention 0x00000000
    Thu Nov 19 14:34:24 2009: --------------------- AIC INIT ------------------------------
    Thu Nov 19 14:34:24 2009: --------------------- Watchdog Disable ---------------------------
    Thu Nov 19 14:34:24 2009: RTCK seems to be bridged with TCK
    Thu Nov 19 14:34:24 2009: Auto JTAG speed: 8000 kHz
    Thu Nov 19 14:34:24 2009: Time limited license: 24 days left
    Thu Nov 19 14:34:25 2009: 13800 bytes downloaded (18.34 Kbytes/sec)
    Thu Nov 19 14:34:25 2009: Loaded debugee: C:\Documents and Settings\Felipe\Desktop\FreeRTOSV6.0.0\FreeRTOS\Demo\ARM7_AT91SAM7S64_IAR\Flash_Debug\Exe\rtosdemo.out
    Thu Nov 19 14:36:00 2009: Target reset
    Thu Nov 19 14:36:09 2009: ---------------------Set PC ---------------------------
    Any ideia to solve this problem ? What i supposed to do ?
Thanks in advance
Felipe
davedoors wrote on Friday, November 20, 2009:
First check that the hardware is working correctly by downloading one of the examples that IAR supply to flash. If the hardware is working then it sounds like there is a configuration problem somewhere probably caused by the project being created in a previous version of Embedded Workbench. You could check the configuration of the linker script and j-link macro files against the working project.
rtel wrote on Sunday, November 22, 2009:
I’ve just tried IAR V5.4 with the SAM7X demo in the FreeRTOS download.  I had to make a couple of changes to get it to flash and run correclty.  Although I cannot explain exactly why some default deep within the IAR configuration seems to have changed regarding the remapping of vectors.
If you update your Demo\uIP_Demo_IAR_ARM7 from the SourceForge SVN repository you will get the changes necessary.  This includes a new macro file called at91sam7x-ek-flash.mac and a change the the linker script at91SAM7X256_FLASH.icf.
