I’ve been working on a STM32(f7) project that uses USB host and device drivers from the STM32 libraries. usbh_core.c and usbd_core.c , I have been able to get the host working under OS pretty well but I now hat to get the usb driver working under RTOS. ST made the host code confrom to FreeRTOS and it is essentially switchable. I havea USB device working now, but it is running in the IDLE thread, which I am asusming isn’t good? So before I move on, I would like to get all that under control. I with ST had done the same things with the usb device as they didi with the host but there aren’t even examples of a USB device with RTOS, that I can find , anyway.
My project is a MIDI project so I have usbd_MIDI.c and usbd_MIDI_if.c performing the midi IO to and from the app. I am a bit lost as to how to get usbd_core to run in its own thread that I can have some control over. I guess I am not really sure what to ask for here as I am still trying to grok how the usb device code works. I believe it is all interrupt driven… I didn’t write it so I am at somewhat of a loss at this point.
So , any hints or links or examples would be very helpful. Thank you for reading and thank you for FreeRTOS.
Sorry nothing specific, but would say it is ok to run in the Idle task provided that the code never blocks the task - by which I mean
never does something like call vTaskDelay(), or wait for a semaphore
with a block time, etc.
task PROVIDED THAT the code never blocks the task - by which I mean
Using FreeRTOS with STM32 usbd_core.c as USB device [1]
Sent from sourceforge.net because you indicated interest in
