jbeik wrote on Thursday, November 13, 2014:
I’m trying to run a test program on a Cortex M0. Without any real success.
I can flash internal memory but my program does not run as expected. In a first time, I only try to switch on and of PB12 line (GPIO).
My configuration:
- FreeRTOSV8.1.2
- gcc 4.9.1 (bare metal)
- STM32F030
I have written a pure C test program. Thus I have used the following ldscript:
OUTPUT_FORMAT("elf32-littlearm", "elf32-bigarm",
"elf32-littlearm")
OUTPUT_ARCH(arm)
ENTRY(Reset_Handler)
SEARCH_DIR(".");
MEMORY
FLASH (rx) : ORIGIN = 0x08000000, LENGTH = 64K
RAM (rwx) : ORIGIN = 0x20000000, LENGTH = 8K
SECTIONS
.text :
. = ALIGN(4);
KEEP(*(.isr_vector))
*(.text)
*(.text*)
*(.rodata)
*(.rodata*)
. = ALIGN(4);
} > FLASH
_data_flash = .;
.data : AT ( _data_flash )
. = ALIGN(4);
_data_begin = .;
*(.data)
*(.data*)
. = ALIGN(4);
_data_end = .;
} > RAM
.bss :
. = ALIGN(4);
_bss_begin = .;
__bss_start__ = _bss_begin;
*(.bss)
*(.bss*)
*(COMMON)
. = ALIGN(4);
_bss_end = .;
__bss_end__ = _bss_end;
} > RAM
_stack_size = 1024;
_stack_end = ORIGIN(RAM)+LENGTH(RAM);
_stack_begin = _stack_end - _stack_size;
. = _stack_begin;
._stack :
. = . + _stack_size;
} > RAM
Loader is:
extern unsigned long _data_flash;
extern unsigned long _data_begin;
extern unsigned long _data_end;
extern unsigned long _bss_begin;
extern unsigned long _bss_end;
extern unsigned long _stack_end;
extern void startup(void);
void
Reset_Handler(void)
unsigned long *source;
unsigned long *destination;
// Copying data from Flash to RAM
source = &_data_flash;
for(destination = &_data_begin; destination < &_data_end;)
*(destination++) = *(source++);
// default zero to undefined variables
for(destination = &_bss_begin; destination < &_bss_end;)
*(destination++) = 0;
// starting main program
startup();
for(;;);
void
Default_Handler(void)
for(;;);
__attribute__ ((section(".isr_vector")))
void (* const table_interrupt_vector[])(void) =
(void *) &_stack_end, // 0 - initial stack pointer
Reset_Handler, // 1 - initial PC
Default_Handler, // 2 - NMI
Default_Handler, // 3 - hard fault
Default_Handler, // 45 - Irq 29
Default_Handler, // 46 - Irq 30
Default_Handler, // 47 - Irq 31
My test program is only :
#include "FreeRTOS.h"
#include "task.h"
#include "stm32f0xx_conf.h"
void
startup(void)
GPIO_InitTypeDef gpio_init;
RCC_AHBPeriphResetCmd(RCC_AHBPeriph_GPIOA, ENABLE);
RCC_AHBPeriphResetCmd(RCC_AHBPeriph_GPIOB, ENABLE);
RCC_RTCResetCmd(ENABLE);
RCC_RTCResetCmd(DISABLE);
RCC_HSEConfig(RCC_HSE_Bypass);
RCC_LSEConfig(RCC_LSE_ON);
while(RCC_GetFlagStatus(RCC_FLAG_LSERDY) == RESET);
RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE);
gpio_init.GPIO_Pin = GPIO_Pin_12;
gpio_init.GPIO_Mode = GPIO_Mode_OUT;
gpio_init.GPIO_Speed = GPIO_Speed_Level_1;
gpio_init.GPIO_OType = GPIO_OType_PP;
gpio_init.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_Init(GPIOB, &gpio_init);
for(;;)
GPIO_SetBits(GPIOB, GPIO_Pin_12);
vTaskDelay(100);
GPIO_ResetBits(GPIOB, GPIO_Pin_12);
vTaskDelay(100);
I can build this test program without any trouble. I have checked with objdump that assembly output is correct:
image.elf: file format elf32-littlearm
Disassembly of section .text:
08000000 <table_interrupt_vector>:
080000c0 <Reset_Handler>:
80000c0: b580 push {r7, lr}
80000c2: b082 sub sp, #8
80000c4: af00 add r7, sp, #0
80000c6: f240 0300 movw r3, #0
80000ca: f2c0 0300 movt r3, #0
80000ce: 607b str r3, [r7, #4]
80000d0: f240 0300 movw r3, #0
80000d4: f2c0 0300 movt r3, #0
80000d8: 603b str r3, [r7, #0]
80000da: e007 b.n 80000ec <Reset_Handler+0x2c>
I suppose I have done a mistake. But where ? Any ideas ?
Thanks a lot in advance,
JB
