Hi !
https:__forums.freertos.org_t_no-tasks-seem-to-run_14326_22
Platform details (hardware, IDE including simulator etc) are the same as from the above post ! (Replace _ with /, since I’m a new user, I can’t insert links ! )
In the following code:
Both tasks are created properly !
The Tx task runs once. I see letters A to X printed to the UART !
- taskYIELD() is called. It seems to work !
The Rx task runs. By placing breakpoints, I can verify that it accepts chars from A to X !
- taskYIELD() is called. But it doesn’t seem to work !
The Rx task runs again ! (Observations similar to the ones in step 3 are seen.)
and so on … ! (the Rx task repeats)
To prevent the timer interrupt from interfering:
I’ve made configUSE_TIMERS equal to 0.
I’ve commented prvSetupTimerInterrupt().
But I’m not sure if the Tx task needs the timer ! (Does it ?)
Since the UART code of FreeRTOS did not work for us:
I replaced xSerialPutChar() with uart_printf()
I replaced xSerialGetChar() with UARTReceiveChar()
Both of these functions seem to work ! (Like I’ve mentioned earlier, printing chars to the UART & accepting chars from the UART seem to work !)
Have you seen this issue before ? Please advice. Thanks in advance !
In main() from main.c
vAltStartComTestTasks( mainCOM_TEST_PRIORITY, mainCOM_TEST_BAUD_RATE, mainCOM_TEST_LED );
From comtest.c:
TaskHandle_t *tx_handle;
void vAltStartComTestTasks( UBaseType_t uxPriority,
uint32_t ulBaudRate,
UBaseType_t uxLED )
/* Initialise the com port then spawn the Rx and Tx tasks. */
uxBaseLED = uxLED;
xSerialPortInitMinimal( ulBaudRate, comBUFFER_LEN );
tx_handle = (TaskHandle_t *) pvPortMalloc(1*sizeof(TaskHandle_t));
/* The Tx task is spawned with a lower priority than the Rx task. */
// Sid - I've tried 3 priorities for the Tx task: uxPriority - 1, uxPriority & uxPriority + 1
// But the Tx task runs just once !
//xTaskCreate( vComTxTask, "COMTx", comSTACK_SIZE, NULL, uxPriority - 1, ( TaskHandle_t * ) NULL );
xTaskCreate( vComTxTask, "COMTx", comSTACK_SIZE, NULL, uxPriority+1, tx_handle );
xTaskCreate( vComRxTask, "COMRx", comSTACK_SIZE, NULL, uxPriority, ( TaskHandle_t * ) NULL );
static portTASK_FUNCTION( vComTxTask, pvParameters )
unsigned char cByteToSend; //char cByteToSend;
TickType_t xTimeToWait;
/* Just to stop compiler warnings. */
( void ) pvParameters;
for( ; ; )
/* Simply transmit a sequence of characters from comFIRST_BYTE to
* comLAST_BYTE. */
for( cByteToSend = comFIRST_BYTE; cByteToSend <= comLAST_BYTE; cByteToSend++ )
//if( xSerialPutChar( xPort, cByteToSend, comNO_BLOCK ) == pdPASS )
uart_printf((BYTE *) &cByteToSend, 1); //if( xSerialPutChar( xPort, cByteToSend, comRX_BLOCK_TIME ) == pdPASS )
vParTestToggleLED( uxBaseLED + comTX_LED_OFFSET );
/* Turn the LED off while we are not doing anything. */
vParTestSetLED( uxBaseLED + comTX_LED_OFFSET, pdFALSE );
/* We have posted all the characters in the string - wait before
* re-sending. Wait a pseudo-random time as this will provide a better
* test. */
xTimeToWait = xTaskGetTickCount() + comOFFSET_TIME;
/* Make sure we don't wait too long... */
xTimeToWait %= comTX_MAX_BLOCK_TIME;
/* ...but we do want to wait. */
if( xTimeToWait < comTX_MIN_BLOCK_TIME )
xTimeToWait = comTX_MIN_BLOCK_TIME;
vTaskDelay( xTimeToWait );
taskYIELD();
} /*lint !e715 !e818 pvParameters is required for a task function even if it is not referenced. */
static portTASK_FUNCTION( vComRxTask, pvParameters )
unsigned char cExpectedByte, cByteRxed; //signed char cExpectedByte, cByteRxed;
BaseType_t xResyncRequired = pdFALSE, xErrorOccurred = pdFALSE;
for( ; ; )
/* We expect to receive the characters from comFIRST_BYTE to
* comLAST_BYTE in an incrementing order. Loop to receive each byte. */
for( cExpectedByte = comFIRST_BYTE; cExpectedByte <= comLAST_BYTE; cExpectedByte++ )
/* Block on the queue that contains received bytes until a byte is
* available. */
//if( xSerialGetChar( xPort, &cByteRxed, comRX_BLOCK_TIME ) )
cByteRxed = UARTReceiveChar(0, 2.0); // Get a char from port 0, wait up to 2.0 minutes if needed !
/* Was this the byte we were expecting? If so, toggle the LED,
* otherwise we are out on sync and should break out of the loop
* until the expected character sequence is about to restart. */
if( cByteRxed == cExpectedByte )
vParTestToggleLED( uxBaseLED + comRX_LED_OFFSET );
xResyncRequired = pdTRUE;
break; /*lint !e960 Non-switch break allowed. */
vParTestSetLED( uxBaseLED + comRX_LED_OFFSET, pdFALSE );
/* Did we break out of the loop because the characters were received in
* an unexpected order? If so wait here until the character sequence is
* about to restart. */
if( xResyncRequired == pdTRUE )
while( cByteRxed != comLAST_BYTE )
/* Block until the next char is available. */
//xSerialGetChar( xPort, &cByteRxed, comRX_BLOCK_TIME );
/* Note that an error occurred which caused us to have to resync.
* We use this to stop incrementing the loop counter so
* sAreComTestTasksStillRunning() will return false - indicating an
* error. */
xErrorOccurred++;
/* We have now resynced with the Tx task and can continue. */
xResyncRequired = pdFALSE;
if( xErrorOccurred < comTOTAL_PERMISSIBLE_ERRORS )
/* Increment the count of successful loops. As error
* occurring (i.e. an unexpected character being received) will
* prevent this counter being incremented for the rest of the
* execution. Don't worry about mutual exclusion on this
* variable - it doesn't really matter as we just want it
* to change. */
uxRxLoops++;
taskYIELD();
