kimokono232 wrote on Thursday, January 02, 2014:
I am using vTaskDelay in every task. I have no problem using a single task.but when I create the second task, one task gets blocked and the other one works correctly in response to its ticks (increments correctly) but it increments again on the tick of the blocked task.
Both tasks start correctly but later it goes wrong as described above.
I have tried to use taskYIELD calls instead of vTaskDelay and it works if priority of both tasks is the same. highest priority task gets blocked if I give different priorities to both created tasks.
I would appreciate any hint or clue on how to find the problem or how to fix it
Regards
