salkaleidoscope wrote on December 19, 2019:
I have been having trouble trying to build my amazon freertos project with OTA library on ESP32 Wrover kit. I have my project setup similar to this project on github where we are using amazon-freertos as a submodule: Link: [https://github.com/ParmanBabra/amazon-freertos-examples]
Similarly, in the CMakeLists.txt file at the root of my project I have
target_link_libraries(my_app PRIVATE AFR::ota)
to try and include the OTA library but we still get this error during the build:
[2/22] Building C object CMakeFiles/my_appdi...ertos_plus/aws/ota/src/mqtt/aws_iot_ota_mqtt.c.obj FAILED: CMakeFiles/my_app.dir/amazon-freertos/libraries/freertos_plus/aws/ota/src/mqtt/aws_iot_ota_mqtt.c.obj
../amazon-freertos/libraries/freertos_plus/aws/ota/src/mqtt/aws_iot_ota_mqtt.c:39:40: fatal error: aws_iot_ota_agent_internal.h: No such file or directory
[3/22] Building C object CMakeFiles/my_app.di...ertos_plus/aws/ota/src/http/aws_iot_ota_http.c.obj FAILED: CMakeFiles/my_app.dir/amazon-freertos/libraries/freertos_plus/aws/ota/src/http/aws_iot_ota_http.c.obj../amazon-freertos/libraries/freertos_plus/aws/ota/src/http/aws_iot_ota_http.c:43:40: fatal error: aws_iot_ota_agent_internal.h: No such file or directory
Is there an error in the include directories for the OTA since library since both aws_iot_ota_mqtt.c and as_iot_ota_http.c files can’t seem to find aws_iot_ota_agent_internal.h? or is there some other way I need to include the OTA library in my project?
