I’m quite new to the FreeRTOS topic and want to port the amazon-freertos repo from Github on my ESP32 DevkitC. Following the getting started guide from amazon isn’t quite working for me when I’m trying to install the PATH variable. It also tells me to download the ESP-IDF V 4.2 before cloning a repo of the amazon-freertos and use this command for the path “vendors/espressif/esp-idf/install.sh”.
But from my understanding this means, that I have to have my repo before installing the esp-tools. The step-by-step solutions don’t make sense to me. Does anyone have an idea how to perform this port?
Sorry for the confusion. I checked the getting start guide, it’s our mistake. Downloading the amazon-freertos repo should be the step before runing the “vendors/espressif/esp-idf/install.sh” script. So please download the amazon-freertos and ESP-IDF v4.2, then follow the steps of “Setting up the toolchain” to setup the ESP-IDF v4.2.
Thank you for pointing this out. We will correct it as soon as possiable.
Thank you for your reply Ming. I made the MQTT demo run and it’s working. Now we wanted to check for the OTA demo and in the step number 2 in: Install the initial version of firmware on the Espressif ESP32 - FreeRTOS
there is no file aws_ota_codesigner_certificate.h anymore in the newest repo. Is there an already updated documentation for it available?
