nobody wrote on Friday, April 08, 2005:
Is it possilbe to Trace the Scheduler directly on the ARM7 Controller not only in Dos? Im using a Philips LPC2138 Controller on an Keil board.
Thanks, sensej
Thanks, sensej
V2.6.1 has the changes, but in this version the definition:
#define tskSIZE_OF_EACH_TRACE_LINE ( sizeof( unsigned portLONG ) + sizeof( unsigned portCHAR ) )
should be:
#define tskSIZE_OF_EACH_TRACE_LINE ( sizeof( unsigned portLONG ) + sizeof( unsigned portLONG ) )
but this does not make too much of a problem.
nobody wrote on Monday, April 11, 2005:
Thanks for quick answer. If I do so my Programm ends in the DAbt_Handler(0x00002CC0). Is there any bad definition of Memory?
rtel wrote on Monday, April 11, 2005:
If your vWriteTraceToBuffer() trace macro is as defined by the V2.6.1 release and the tskSIZE_OF_EACH_TRACE_LINE definition is corrected as per the other post in this thread then the only other thing I can suggest is to check that the trace buffer is aligned on a four byte boundary. I’m not sure if the compiler will do this automatically for a byte array. You can force it using a #pragma, or by placing it in a struct following a long as per:
struct xBuffer
unsigned long ulDummy; // This will get alligned
char cTraceBuffer[ BUFFER_SIZE ];
Failing this, you can send me your modified file (presumably trace.c) and I can take a look at it (use the email address form the contacts page of the FreeRTOS.org web site).
Which processor are you using? I might be able to give it a go.
I meant tasks.c as the modified file - not trace.c!
If the trace is already started when the scheduler starts then the time stamp will be zero - as in this file segment.
