nobody wrote on Monday, January 29, 2007:
Hallo,
i’m doing some tests with FreeRTOS on ATMEL AVR (ATmega32) and i have a problem with the vTaskStartTrace() function.
In my main.c i have defined a buffer:
#define BUFFER_SIZE ( ( unsigned portSHORT ) 512 )
static portCHAR pcWriteBuffer[BUFFER_SIZE];
I call vTaskStartTrace(pcWriteBuffer, BUFFER_SIZE) in a suicid-task. I think after calling vTaskStartTrace() there shoult be a list in memory on adress pcWriteBuffer. I copied the data on this adress into i file (then hex2bin and tracecon). But the result can’t be correct:
1950631244.000000 29537
1145392128.000000 29537
1145392128.000000 24948
1224867890.000000 24948
1224867890.000000 19524
151614245.000000 19524
151614245.000000 25381
1965361525.000000 25381
1965361525.000000 9481
168624138.000000 9481
168624138.000000 0
43264.000000 0
43264.000000 0
66304.000000 0
66304.000000 3
0.000000 3
0.000000 0
0.000000 0
0.000000 0
0.000000 0
What have i done wrong? I’m new in freertos and also in c, so sorry, if it is my mistake!
Kristian
