mike-sole wrote on Thursday, July 05, 2018:
I have a STM32F105 uC running FreeRTOS v10.0.1 and all my timers work until I enter low-power mode (standby) and exit.
I use a timer to synchronize a task and after exiting the sleep mode, the callback is no longer called.
My thread waits on a semaphore with portMAX_DELAY. When a timeout occurs, the callback gives the semaphore and allows the thread to run.
I realized the problem because I use an event group to kick the watchdog, but the uC keeps resetting due to the watchdog which means the semaphore was never given. I have placed breakpoints and I know the thread is waiting on the Semaphore (which should be given by the timer).
I have another task that uses the same strategy (timer and a callback with a semaphore give) and that works.
I have tried using different power modes thinking that the RAM retention might have something to do with it, but I get the same results in all modes. When I remove the sleep altogether, everything works.
How can I check what state the timer service or the state of a specific timer so I know why it is not firing?
As far as I can tell, the timer in question is Active (I used xTimerIsTimerActive and it returns pdTRUE).
I don’t see any button allowing me to attachf iles, however, if you need to see it, give me an email address so I can forward it.
I am just wondering what I am doing wrong which causes the timer to not work anymore.
Regards,
Michel
