static void vTaskAd( void *pvParameters ); //broadcast the ATYPE packets
static void vTaskSu( void *pvParameters ); //read the socket and check the SType packets
static void vTaskPu( void *pvParameters ); //broadcast the PTYPE packets
Let suppose Subscription packets are generated every 10sec.
1. vTaskAd runs continuously until any reception of the
STYPE packet
2. vTaskSu(read the STYPE packets every time) run
continuously
3. If it found the STYPE packet then vTaskPu task will
start.
4. vTaskAd will goes to sleep until let suppose TTL=
1000ms and the vTaskPu will run till TTL=1000ms
5. After 1000ms the vTaskSu task again starts and do the
same above steps.
Could anyone please guide me I am facing problem with the time management of the tasks.
Let suppose SType packets are generated every 10sec.
STYPE packet
continuously
start.
same above steps.
You are saying that vTaskAd runns until vTaskSu receives an SType packet (what ever that is)? Therefore task vTaskSu has to suspend vTaskAd when it receives a packet? Is this correct?
By default vTaskAd runs in the begning and vTaskSu keep listening the packets.
if in the mean time vTaskSu receive any Stype packets then it will suspend the vTaskAd(let suppose 1000ms) and it will run vTaskPu for the time of 1000ms. after 1000ms it will resume the vTaskAd…
I have not try time scheduling with freeRTOS could you please guide me what will be the commands for these tasks.
I think the simplest way would be to simply call vTaskSuspend() to suspend the tasks when necessary. You can keep a track of the tick count, then call vTaskResume() when the time comes. You might even suspend one task, then call vTaskDelay( 1000 ) to know when it is time to resume it, and call vTaskResume() as soon as you unblock (assuming there is nothing else to do in the mean time).
