After reading throught the FreeRTOS “A Guide…” I’m still unsure just the right way to implement what I’m needing to do, and hoping for some advice. It’s fairly straightforward:
Task 1 runs every 30 seconds.
When Task 2 runs, I need to suspend just Task 1 (no other task) until Task 2 is complete.
It isn’t totally clear what you mean, as, has been commented, if Task 2 has a higher priority than Task 1, then when ever task 2 is running task 1 is not (since FreeRTOS doesn’t to my knowledge support multi-core processors). If what you mean is that every time you create a copy of Task2 with vTaskCreate or signal a semaphore/queue that Task2 is waiting on, you want Task 1 suspended until Task2 gets ready to end/block again, then use vTaskSuspend/Resume in Task2, with Task 1 as the target.
