karimaaissaoui wrote on Tuesday, April 19, 2016:
Hello everyone,
we have created several tasks with different priorities, tasks are created, and this is the task that has the highest priority that runs without going to the other, in our case 3 tasks allow to light and turn off the LEDs.
The first task turns on the LED without turning off, and the program remains in the infinite loop, because the “vTaskDelay ()” function does not work correctly, therefore other tasks do not run .
When loading the program into the microcontroller, the function used by the task turns the LED, and an interruption is generating : “ISR (Cpu_Interrupt)”
** Method : Cpu_Cpu_Interrupt (component MC9S12P128_64)
** Description :
** The method services unhandled interrupt vectors.
** This method is internal. It is used by Processor Expert only.
ISR(Cpu_Interrupt)
/*lint -save -e950 Disable MISRA rule (1.1) checking. */
#ifdef debug
asm(BGND);
_EntryPoint;
asm(BGND);
/*lint -restore Enable MISRA rule (1.1) checking. */
We are stuck in this phase, and we hope to have your opinion
We thank you in advance, and we apologize for the inconvenience.
Best Regards.
FreeRTOSV9 microcontroller : HCS12P64 codeWarrior V5.9.0
