andrewfrazer wrote on Monday, February 22, 2016:
I’m new to working with both freeRTOS and Harmony and have run into a problem that is causing me some issues;
Im using MPLAB 3.20, and Harmony 1.06
I’m trying to get the TCP/IP stack + freeRTOS working together in the same stack. It just doe’snt want to play for me…
I created a new project, based around a PIC32MX795P512-L ( using an ethernet Starter Kit 2 ), and set up the TCP/IP etc, used the appropriate BSP files, added a file system. and it all works without any issues…
Then go back and add FreeRTOS into the mix using the Harmony Configurator;
Selected FreeRTOS_V8.x.x
Memory management Type is Heap5
The Tick Rate is 1000Hz
Total Heap Size is 10240
There were no changes in any code when it was generated. The code compiles ands installs on the Starter Kit 2, but does not seem to operate correctly. When i debug the code, i end up in the
vApplicationMallocFailedHook() loop, when the tasks are created ( before starting the scheduler ).
This is my SYS_Task… It doesnt get past the first part.
void SYS_Tasks ( void )
/* Create OS Thread for Sys Tasks. */
xTaskCreate((TaskFunction_t) _SYS_Tasks,
"Sys Tasks",
1024, NULL, 1, NULL);
/* Create OS Thread for APP Tasks. */
xTaskCreate((TaskFunction_t) _APP_Tasks,
"APP Tasks",
* Start RTOS *
vTaskStartScheduler(); /* This function never returns. */
any pointers woud be greater appreicated.
