giso1 wrote on Friday, April 27, 2018:
I have the following pseudo code
task_run()
while (true)
xTaskNotifyWait(eventA|eventB)
if (eventA)
send RF command
xTaskNotifyWait(eventA)
if (eventB)
process command
do something else
EventA is triggered by interrupt when RF data is received.
EventB is triggered when application request to trigger a cmd
I have the following issue when I have the following sequence
- EventA received
- task is woken up
- EventB occurs before the second xTaskNotifyWait is called
the first xTaskNotifyWait(eventA|eventB) will not detect eventB.
to simulate I do the following
task_run()
while (true)
if (eventA)
trigger EventB
send RF command
if (eventB)
process command
do something else
Is that the expected behaviour?
I would have expected that when waiting for a specific event, xTaskNotifyWait would only retrieve these specific events and if other event have been set they would be kept and available for other call to xTaskNotifyWait.
Thanks for feedback.
