xTaskNotifyWait() not processing a specific notification
I have the code below
case APP_PRINT_LABEL_WAITING_LABEL_UPLOAD:
    if (xTaskNotifyWait(0, 0, &uiCurrentNotificationValue, portMAX_DELAY) == pdTRUE)
        //notification received
        _nop();
        if (uiCurrentNotificationValue == NOTIF__PRINT_LABEL__LBL_UPLOADED)
            app_print_labelData.state = APP_PRINT_LABEL_STATE_STANDBY;
    break;
Which is in a Switch statement which in turn is in a loop.
The program arrives at that point (I checked with the debugger) and then, as you can see the code keeps effectively looping inside that “case APP_PRINT_LABEL_WAITING_LABEL_UPLOAD:” block because nowhere in the code that state is changed. And I also double checked. It keeps looping in there.
To that task I send various DIFFERENT messages including the one below:
xTaskNotify(xAPP_PRINT_LABEL_Tasks, NOTIF__PRINT_LABEL__LBL_UPLOADED, eSetBits);
But it never gets processed, it keeps getting inside the IF brackets but never recognises the message NOTIF__PRINT_LABEL__LBL_UPLOADED
I assume that all other messages that I send are just read and purged/discarded by the xTaskNotifyWait() automatically even if I don’t do anything inside that. Is that correct?
Do I have perhaps to set/clear some flags?
Am I using the the xTaskNotifyWait() incorrectly?
Ultimately what I need to do is what I assumed above… To have that xTaskNotifyWait() discard all messages that have been sent to that task and are in the task queue until that specific one arrives.
Also, I am pretty sure I am not passing the wrong task pointer in the xTaskNotify(), but how can U double check?
Thank you
You can read this page to see how xTaskNotify works: xTaskNotify() RTOS task notification API documentation
In case of eSetBits, it will just set the specific bits. Therefore, the check should in your if should be:
if ((uiCurrentNotificationValue & NOTIF__PRINT_LABEL__LBL_UPLOADED) != 0 )
Thank you Gaurav!
That solved it.
