For some reason SysTick_Handler() doesn’t get called after prvPortStartFirstTask(). More specifically, it stops being called somewhere after the first call to xPortPendSVHandler() and actually switching to the first task.
This doesn’t happen if I don’t include one of the main tasks, but I can’t narrow it down any further.
Here’s how it’s initialized:
const size_t task_stack_depth_bytes = 5000;
const uint32_t task_stack_depth_words = task_stack_depth_bytes / 4;
StackType_t task_stack_buffer[task_stack_depth_words] = { 0 };
StaticTask_t task_tcb;
TaskHandle_t task_handle;
static void task_task(void* arg);
void setup() {
task_handle = xTaskCreateStatic(task_task, NULL, task_stack_depth_ints, NULL, 1, task_stack_buffer, &task_tcb);
PREFETCH_ENABLE is set to 0, so it shouldn’t be anything related to a HW bug that’s present in my MCU.
Going through the FAQ:
SysTick_Handler() gets called initially, and FreeRTOSConfig_Default.h has the right lines:
so its not point #1.
It’s not a stack overflow since I’ve set configCHECK_FOR_STACK_OVERFLOW and the tasks have more than enough memory. So its not point #2.
I am allocating the tasks statically and the buffers are in global space. So it’s not point #3.
When entering the first task, uxCriticalNesting is equal 0, and NVIC_INT_CTRL_REG has the same value as before calling the scheduler, so I’m pretty sure, but not certain, that it’s not point #4.
I’m not using any dynamical memory at all (and _sbrk() never gets called), so it’s not point #5.
None of my interrupts are called before the first task, so not #6.
CONTROL->nPRIV == 0 when the scheduler gets called, so not #7.
Board: STM32F407VG (Rev A) Disco (MBB997 B-00)
IDE: PlatformIO, Arduino as a Framework
