I use FreeRTOS for a microcontroller device, and now want to simulate FreeRTOS on Ubuntu to run Ceedling tests.
Starting timer with a callback gives me either a lot of callbacks if timer period == 200 msec, or zero callbacks, if timer period == 2000 msec for a period of 5 seconds
static void test_timer_callback(TimerHandle_t xTimer) {
printf("test_timer_callback \n");
test_timer = xTimerCreate("test_timer", pdMS_TO_TICKS(2000), pdTRUE, (void *)0,
test_timer_callback); //2000 - zero callbacks, 200 msec - a LOT of callbacks
xTimerStart(test_timer, pdMS_TO_TICKS(10));
Also, when I call xTimerStop function - the function contains xTimerStop fall without any errors
I use FreeRTOSConfig.h file from blinky example
#define configUSE_PORT_OPTIMISED_TASK_SELECTION 0
#define configUSE_IDLE_HOOK 0
#define configUSE_TICK_HOOK 0
#define configUSE_DAEMON_TASK_STARTUP_HOOK 0
#define configTICK_RATE_HZ ( 1000 ) /* In this non-real time simulated environment the tick frequency has to be at least a multiple of the Win32 tick frequency, and therefore very slow. */
#define configMINIMAL_STACK_SIZE ( ( unsigned short ) 70 ) /* In this simulated case, the stack only has to hold one small structure as the real stack is part of the win32 thread. */
#define configTOTAL_HEAP_SIZE ( ( size_t ) ( 65 * 1024 ) )
#define configMAX_TASK_NAME_LEN ( 12 )
#define configUSE_MUTEXES 1
#define configCHECK_FOR_STACK_OVERFLOW 0
#define configUSE_RECURSIVE_MUTEXES 1
#define configQUEUE_REGISTRY_SIZE 20
#define configUSE_APPLICATION_TASK_TAG 1
#define configUSE_COUNTING_SEMAPHORES 1
#define configUSE_ALTERNATIVE_API 0
#define configUSE_QUEUE_SETS 1
#define configUSE_TASK_NOTIFICATIONS 1
#define configSUPPORT_DYNAMIC_ALLOCATION 1
/* Software timer related configuration options. The maximum possible task
* priority is configMAX_PRIORITIES - 1. The priority of the timer task is
* deliberately set higher to ensure it is correctly capped back to
* configMAX_PRIORITIES - 1. */
#define configUSE_TIMERS 1
#define configTIMER_TASK_PRIORITY ( configMAX_PRIORITIES - 1 )
#define configTIMER_QUEUE_LENGTH 20
#define configTIMER_TASK_STACK_DEPTH ( configMINIMAL_STACK_SIZE * 2 )
Hey,
I have tried the timers with both 200ms and 2000ms and they look fine to me.
I used the default config file from the posix port and also modified it to match the one you posted
the only difference is:
[Posix_GCC]$ ./build/posix_demo
Trace started.
The trace will be dumped to disk if a call to configASSERT() fails.
Starting echo blinky demo
Message received from task
test_timer_callback
Message received from software timer
test_timer_callback
test_timer_callback
test_timer_callback
test_timer_callback
test_timer_callback
With 200 ms
Trace started.
test_timer_callback
test_timer_callback
test_timer_callback
test_timer_callback
test_timer_callback
test_timer_callback
test_timer_callback
test_timer_callback
test_timer_callback
test_timer_callback
test_timer_callback
test_timer_callback
test_timer_callback
test_timer_callback
test_timer_callback
test_timer_callback
test_timer_callback
test_timer_callback
test_timer_callback
test_timer_callback
test_timer_callback
test_timer_callback
test_timer_callback
test_timer_callback
My guess is that you are doing something that is not shown in the fragment you have posted.
