biradarajinkya wrote on Monday, February 04, 2013:
Hello friends,
I am using STR912 comstick with IAR embedded workbench which generates .out file which I am flashing using openocd+telnet as IAR flash using GDB is not working properly.
I am using “Ethernet demo” provided on freeRTOS site to generate PWM signal on GPIO for IR signal of a remote.
I am able to start and generate variable width PWM as I wanted. But I want it to stop after around 30 pulses are over, but I am not able to stop it, It keeps repeating that 30 pulse sequence.
I mean If I clear CR1 register (which is used for initial settings of timer and PWM) then it enters in abort mode or undefined instruction mode or it will just not start.
I have tried various possible things to make it work. But it is just not working as expected.
If any body worked on this or similar like this please guide me.
