telkim wrote on Thursday, April 01, 2010:
I use freertos version 5.0.2 and lwip.
target board program following code for server
1. calling founction
void vBasicWEBServer( void *pvParameters ) // basicweb.c
unsigned char pcMessageToExchange = “\n init socket\r\n”;
struct ip_addr xIpAddr, xNetMast, xGateway;
extern err_t ethernetif_init( struct netif *netif );
/* Parameters are not used - suppress compiler error. */
( void ) pvParameters;
/* Create and configure the EMAC interface. */
IP4_ADDR( &xIpAddr, emacIPADDR0, emacIPADDR1, emacIPADDR2, emacIPADDR3 );
IP4_ADDR( &xNetMast, emacNET_MASK0, emacNET_MASK1, emacNET_MASK2, emacNET_MASK3 );
IP4_ADDR( &xGateway, emacGATEWAY_ADDR0, emacGATEWAY_ADDR1, emacGATEWAY_ADDR2, emacGATEWAY_ADDR3 );
netif_add( &EMAC_if, &xIpAddr, &xNetMast, &xGateway, NULL, ethernetif_init, tcpip_input );
/* make it the default interface */
netif_set_default( &EMAC_if );
/* bring it up */
netif_set_up(&EMAC_if);
vSerialPutString( 0, pcMessageToExchange, strlen( pcMessageToExchange ) );
/* Initialize HTTP */
// httpd_init(); //kcs
kcs_server(); // kcs
/* Nothing else to do. No point hanging around. */
vTaskDelete( NULL );
void kcs_server() // httpd.c
struct tcp_pcb *pcb;
pcb = tcp_new();
tcp_bind(pcb, IP_ADDR_ANY,2000);
tcp_arg(pcb,NULL);
pcb = tcp_listen(pcb);
tcp_accept( pcb, helloworld_accept);
void helloworld_accept( void *arg, struct tcp_pcb *pcb, err_t err) // kcs
int i,j;
vSerialPutString( 0, “accept\r\n”, 10 );
vSerialPutString( 0, “read\r\n”, 8 );
tcp_err(pcb,conn_err); // 2010.3.4 kim
tcp_recv(pcb, kcs_receive);
for(j = 0; j < 1; j++)
vSerialPutString( 0, “write\r\n”, 9 );
tcp_write(pcb, GREETING, strlen(GREETING),1);
for( i = 0; i < 100;i++) ;
err_t kcs_receive(void *arg, struct tcp_pcb *pcb, struct pbuf *p, err_t err) // kcs
int i;
vSerialPutString( 0, “receive\r\n”, 11);
if( p != NULL)
tcp_recved(pcb,p->tot_len); // add kcs 2010.3.4
vSerialPutString( 0, p->payload, p->tot_len );
err = tcp_write(pcb,p->payload,p->tot_len ,1);
else if( err == ERR_OK)
vSerialPutString( 0, “socket close\r\n”, 16 );
tcp_close(pcb);
err = tcp_write(pcb,p->payload,p->len,1);
Above code run 8 times packet and ping reply, but don’t run 9 times. and ping don’t reply
why did it run?
