Hi
I have a hard fault problem when sending data into a queue from an interrupt (i2c), if the array is filled with a few bytes <12 it doesn’t crash, but when I send the array with eg 20 bytes I get the hard-fault. I have read the M3 book and searched the web but cant figure out the problem. Can any one please look at my setup to see if I have misunderstood the priority handling? And I’m also wondering what a suitable array size would be?
freertosConfig.h
#define configLIBRARY_LOWEST_INTERRUPT_PRIORITY 15
#define configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY 5
/* The lowest priority. */
#define configKERNEL_INTERRUPT_PRIORITY ( configLIBRARY_LOWEST_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
/* Priority 5, or 95 as only the top four bits are implemented. */
#define configMAX_SYSCALL_INTERRUPT_PRIORITY ( configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
interrupt setup
//Interuptconfig, viktigt att I2C har högst prio, se errata.
NVIC_InitStructure.NVIC_IRQChannel = I2C1_EV_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 11; //Lågt värde => hög prio
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //Lågt värde => hög prio
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 12; //Lågt värde => hög prio
NVIC_InitStructure.NVIC_IRQChannel = I2C1_ER_IRQn;
NVIC_SetPriority(I2C1_ER_IRQn,10);
NVIC_SetPriority(I2C1_EV_IRQn,11);
// term_I2C enable
I2C_Cmd(term_I2C, ENABLE);
I2C ISR
portBASE_TYPE xHigherPriorityTaskWoken = pdFALSE;
if (I2C_GetITStatus(term_I2C, I2C_IT_RXNE)) {
vBMT_ReciveByte(&xHigherPriorityTaskWoken);
I2C_ClearITPendingBit(term_I2C, I2C_IT_RXNE);
portEND_SWITCHING_ISR(xHigherPriorityTaskWoken);
vBMT_ReciveByte()
save data to RxBuf until complete package
if(xQueueSendToBackFromISR(xNMTRxQueue, &RxBuf, xHigherPriorityTaskWoken)==errQUEUE_FULL){
//TODO:Lyckades inte skriva till kön gör en reset!?
goes back to handler
To expand on Friedl’s comment, portEND_SWITCHING_ISR is supposed to be the VERY LAST step of your ISR, for many (most?, all?) ports, what follows might not get run until the task that was interrupted get run again.
My code example above might be a bit unclear, I don’t call portEND_SWITCHING before, its a function(vBMT_ReciveByte(…)) call before witch sends to the queue.
} portEND_SWITCHING_ISR(xHigherPriorityTaskWoken);
vBMT_ReciveByte(......){
save data to RxBuf until complete package then:
//TODO:
}goes back to handler & the portEND_SW
Tried using a semaphore instead and got the same error so its something with the context switch that fails
anywhere during your initialisation to ensure all 4 priority bits are set as preemption priority rather than sub priority? In my experience this is necessary when using STM32 parts - whereas other manufacturers parts default to that anyway.
The functions do different things. NVIC_SetPriority() sets the preemption and sub priority values for one interrupts, but does not tell the Cortex NVIC how many bits to use for each. You have to tell it how many bits to use for each before the values passed into NVIC_SetPriority() make sense. For example, you can try to set the sub priority to 2 in a call to NVIC_SetPriority, but the sub priority will still be 0 if NVIC_PriorityGroupConfig has set the number of bits to use for the sub priority to 0. Another example, if you use NVIC_PriorityGroupConfig to set the number of sub priority bits to 1, then using NVIC_SetPriority to set a sub priority value of 2 is invalid because only 0 and 1 are valid when a single bit is used.
I’m thinking that it might have something to do with the ISR stack, where can I configure its size?
The error only appears when the received packed is long, so I must overwrite some memory.
I used the memory browser to see if my buffer overwrote any memory but it looks ok.
