Hi.
I have been trying hard to get my FreeRTOS v7.3.0 system working together with lwIP v1.4.1 and I have sucessfully managed to get connection and DHCP.
But when I try to use sockets it only works sometimes.
Most of the times it takes long, trying to connect, and then it times out.
I have been trying almost everything from changing the Heap Size, changing the TCP-IP stack and priority.
But as I don’t know that much about RTOS yet, I am unsure if the problem might have something to do with interrupt priority of the Ethernet layer.
I don’t know if the NVIC IRQ Priority of the Ethernet HAL should be set lower or higher.
I have been trying with
You would have to look at the execution pattern of the system to determine what was being slow. For example, does the stack start executing immediately that data is received, or is there a delay because the task processing the data is too low priority. Likewise when anything gets posted on a queue, are the sending task and receiving task running right away or waiting for other higher priority tasks to finish first? Etc.
I can’t answer the question as to what the interrupt priority should be without knowing what your configMAX_SYSCALL_INTERRUPT_PRIORITY value is set to in FreeRTOSConfig.h. Basically it needs to be no higher than that (which on a Cortex-M means a numerically lower value). See the following page: http://www.freertos.org/RTOS-Cortex-M3-M4.html and particularly note the requirement to call NVIC_PriorityGroupConfig( NVIC_PriorityGroup_4 ); on STM32 parts.
I have now done some logging and package sniffing and it seems like the webserver in the other end doesn’t respond to the requests, rather than a problem with the RTOS and the lwIP stack.
This is the log:
root@DD-WRT:/tmp/smbshare/tmp/ipkg# tcpdump host 192.168.0.136
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on br0, link-type EN10MB (Ethernet), capture size 96 bytes
21:06:16.755439 arp who-has 192.168.0.136 tell DD-WRT
21:06:17.749425 arp who-has 192.168.0.136 tell DD-WRT
21:06:18.749419 arp who-has 192.168.0.136 tell DD-WRT
21:06:19.009820 IP DD-WRT > 192.168.0.136: ICMP echo request, id 24829, seq 0, length 28
21:06:19.010268 IP DD-WRT.bootps > 192.168.0.136.bootpc: BOOTP/DHCP, Reply, length: 300
21:06:19.013484 IP DD-WRT.bootps > 192.168.0.136.bootpc: BOOTP/DHCP, Reply, length: 300
21:06:19.013816 arp who-has 192.168.0.136 tell 0.0.0.0
21:06:19.253541 arp who-has 192.168.0.136 tell 0.0.0.0
21:06:20.755843 arp who-has DD-WRT tell 192.168.0.136
21:06:20.756171 arp reply DD-WRT is-at 00:1c:10:36:55:d5 (oui Unknown)
21:06:20.756363 IP 192.168.0.136.49153 > api.theblast.dk.www: S 6509:6509(0) win 5840 <mss 1460>
21:06:23.505626 IP 192.168.0.136.49153 > api.theblast.dk.www: S 6509:6509(0) win 5840 <mss 1460>
21:06:26.505681 IP 192.168.0.136.49153 > api.theblast.dk.www: S 6509:6509(0) win 5840 <mss 1460>
21:06:29.505745 IP 192.168.0.136.49153 > api.theblast.dk.www: S 6509:6509(0) win 5840 <mss 1460>
21:06:32.505805 IP 192.168.0.136.49153 > api.theblast.dk.www: S 6509:6509(0) win 5840 <mss 1460>
21:06:35.505865 IP 192.168.0.136.49153 > api.theblast.dk.www: S 6509:6509(0) win 5840 <mss 1460>
21:06:38.505924 IP 192.168.0.136.49153 > api.theblast.dk.www: S 6509:6509(0) win 5840 <mss 1460>
STM32 Debug: TIMEOUT
21:06:40.058179 IP 192.168.0.136.49154 > api.theblast.dk.www: S 6583:6583(0) win 5840 <mss 1460>
21:06:43.058028 IP 192.168.0.136.49154 > api.theblast.dk.www: S 6583:6583(0) win 5840 <mss 1460>
21:06:46.058071 IP 192.168.0.136.49154 > api.theblast.dk.www: S 6583:6583(0) win 5840 <mss 1460>
21:06:49.058133 IP 192.168.0.136.49154 > api.theblast.dk.www: S 6583:6583(0) win 5840 <mss 1460>
21:06:52.058188 IP 192.168.0.136.49154 > api.theblast.dk.www: S 6583:6583(0) win 5840 <mss 1460>
21:06:55.058256 IP 192.168.0.136.49154 > api.theblast.dk.www: S 6583:6583(0) win 5840 <mss 1460>
21:06:58.058307 IP 192.168.0.136.49154 > api.theblast.dk.www: S 6583:6583(0) win 5840 <mss 1460>
21:06:59.565567 IP 192.168.0.136.49155 > api.theblast.dk.www: S 6731:6731(0) win 5840 <mss 1460>
21:06:59.587891 IP api.theblast.dk.www > 192.168.0.136.49155: S 2608560878:26085 60878(0) ack 6732 win 14600 <mss 1460>
21:06:59.588153 IP 192.168.0.136.49155 > api.theblast.dk.www: . ack 1 win 5840
21:06:59.589999 IP 192.168.0.136.49155 > api.theblast.dk.www: P 1:164(163) ack 1 win 5840
21:06:59.611974 IP api.theblast.dk.www > 192.168.0.136.49155: . ack 164 win 15544
21:06:59.677696 IP api.theblast.dk.www > 192.168.0.136.49155: P 1:221(220) ack 164 win 15544
21:06:59.678214 IP api.theblast.dk.www > 192.168.0.136.49155: F 221:221(0) ack 164 win 15544
21:06:59.678451 IP 192.168.0.136.49155 > api.theblast.dk.www: . ack 222 win 5619
21:06:59.729786 IP 192.168.0.136.49155 > api.theblast.dk.www: F 164:164(0) ack 222 win 5619
21:06:59.750428 IP api.theblast.dk.www > 192.168.0.136.49155: . ack 165 win 15544
In that case, as the server isn’t responding properly, could it be something with the HTTP header?
The header I’m sending/using is:
GET / HTTP/1.1\r\nUser-Agent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1; .NET CLR 1.1.4322; .NET CLR 1.0.3705)\r\nHost: api.theblast.dk\r\n\r\n
