I have an example application for my target hardware (ATMEL EVK1100 / AT32UC3A0512) which runs the lwIP stack in a FreeRTOS task.
I tried to activate DHCP for my application. This seems to work fine. At least I can obtain an IP address from the DNS. The problem is that it only works as long as the task priority is set to 7 or 8 (maximum is configured to 8). With lower priorities a ping to the given address stays unanswered. The high priority has the bad effect of starving my other tasks.
Has anybody an idea what problem I am facing? Similar experiences?
Thanks for your opinion. Regards,
Mathias
That really depends how you have written the Ethernet driver, the priority of other tasks in the system, and what the other tasks in the system are doing.
Thanks for your reply. One thing that is strange anyway: Even when I only start the Ethernet task PING only works with task priority 7 or 8. What else could cause the problems? Are there any other tasks running by default which could block my Ethernet task?
If anyone knows a sample or demo application runs lwIP stack with FreeRTOS on LM3S6965 (Cortex-M3)? I have a demo application (Cortex_M3_IAR_Keil) that runs only uIP stack without DHCP functionality. So if I need to DHCP, I need to run lwIP stack, right?
I have some code I could send although I don’t know if it uses DHCP or not. There is an ARM9 lwIP demo that uses DHCP you could look at though. uIP should also work with DHCP.
If you want the code write to me at r (dot) barry _at_ freertos.org. Don’t use the SourceForge email service as I have no idea how it works.
