I have used the Stae viewer in the IAR 5.3 version without problems. But since I´ve upgraded to the latest version, I can´t run it. I have added the plugin as is explained in the manual but when I exit the debugger plugins windows after checking the FreeRtos option, it appears an error message saying that the files is corrupt or wrong. And obviusly when you run the debugger the state viewer doesn´t appear.
After solving the installation problem, I found that I have another one. I can monitor the tasks correctly but there is no information about the queues, which are correctly added to the viewer using the vQueueAddToRegistry function as I used to in the previous version of IAR and worked fine.
