nobody wrote on Saturday, February 17, 2007:
I’m using the FreeRTOS with a dspic33f device. I did a modification on the function pxPortInitialiseStack to add the stack depth parameter. The purpose is to use the stack limit register (WREG15) to protect against stack overflow.
For this modification I also changed the tark.c file (normaly this file should not be modified).
I’m wondering if this parameter will be added on a next release?
