system
(system)
December 16, 2011, 2:53pm
1
patrickecr wrote on Friday, December 16, 2011 :
Hi
I’m debugging a new project which runs with FreeRTOS and have got an problem during debugging the source.
Problem:
Everytime I set a breakpoint in one task, there are three taks running (quasi-)parallel, it stops there and next time never gets to this BP again. When I stop the application I see, that the vApplicationStackOverflowHook()-function was called. The other 2 tasks are still running fine. But the task I want to debug, is now in the endless-for-loop…
I can also do the same with one of the two other running tasks, which also stops then after reaching the overflow-function…
Any suggestions?
Best regards
Patrick
system
(system)
December 16, 2011, 3:09pm
2
davedoors wrote on Friday, December 16, 2011 :
Any suggestions?
Yes - tell us which chip and compiler you are using.
system
(system)
December 19, 2011, 6:55am
3
patrickecr wrote on Monday, December 19, 2011 :
Omg … bad job from my side to forget it.
I use MCF52259 (on MCF52259EVB) from Freescale. IDE CW 10.1, I use the included Coldfire-Compiler there.
The code I use is the following:
#define Queue_Active 0
unsigned int counter;
unsigned int counter_T2;
xQueueHandle xQueue1;
static portTASK_FUNCTION(vMainTask, pvParameters) {
const portTickType xDelay = 2/portTICK_RATE_MS;
portTickType xActual = 0;
#if Queue_Active
counter = 0;
xQueue1 = xQueueCreate(4, sizeof(unsigned int));
if(xQueueSend(xQueue1,&counter,10) != pdPASS ){
portNOP();
for(;;){
xActual = xTaskGetTickCount();
vTaskDelayUntil(&xActual,xDelay);
#if Queue_Active
portENTER_CRITICAL();
Bit1_NegVal();
#if Queue_Active
xQueueReceive(xQueue1,&counter,1);
counter++;
xQueueSend(xQueue1,&counter,1);
counter = 0;
portEXIT_CRITICAL();
static portTASK_FUNCTION(vMainTask2, pvParameters) {
for(;;){
vTaskDelay(xDelay);
#if Queue_Active
Bit2_NegVal();
#if Queue_Active
xQueueReceive(xQueue1,&counter_T2,1);
counter_T2++;
xQueueSend(xQueue1,&counter_T2,1);
counter_T2 = 0;
static portTASK_FUNCTION(vMainTask3, pvParameters) {
const portTickType xDelay = 10/portTICK_RATE_MS;
for(;;){
vTaskDelay(xDelay);
Bit3_NegVal();
I already tried to increase stack ov all and of certain tasks (from standard 600 to 2.4k) but without success.
Thx!
Best regards
Patrick
