Help me to make this link error "vApplicationStackOverflowHook
immanuvel wrote on Wednesday, October 16, 2013:
I am a beginner in freertos. Please Help me
When I compile this small below program it has compiled but it is not make.i am getting Link Error.
Link Error: Undefined: “vApplicationStackOverflowHook” Referenced from “vTaskSwitchContext” in.
(and i am using Coldfire MCF52259 Microcontroller)
#include “FreeRTOS.h”
#include “task.h”
#include “queue.h”
#include “timers.h”
void mytask(void *pvParameters)
while(1)
MCF_GPIO_DDRTC=0x0F;
MCF_GPIO_SETTC=0x0F;
vTaskDelay( 500 / portTICK_RATE_MS);
MCF_GPIO_CLRTC=0x0F;
int main(void)
xTaskCreate(mytask,(signed char*) "mytask", configMINIMAL_STACK_SIZE, NULL, 1, NULL);
return 0;
This is FreeRTOSConfig.h file which i have used for this above program
#ifndef FREERTOS_CONFIG_H
#define FREERTOS_CONFIG_H
/* Library includes. */
#include “common.h”
  • Application specific definitions.
  • These definitions should be adjusted for your particular hardware and
  • application requirements.
  • THESE PARAMETERS ARE DESCRIBED WITHIN THE ‘CONFIGURATION’ SECTION OF THE
  • FreeRTOS API DOCUMENTATION AVAILABLE ON THE FreeRTOS.org WEB SITE.
  • See http://www.freertos.org/a00110.html.
#define configUSE_IDLE_HOOK 0
#define configUSE_TICK_HOOK 0
#define configCPU_CLOCK_HZ ( ( unsigned long ) 80000000 )
#define configTICK_RATE_HZ ( ( portTickType ) 100 )
#define configMINIMAL_STACK_SIZE ( ( unsigned short ) 160 )
#define configTOTAL_HEAP_SIZE ( ( size_t ) (30* 1024 ) )
#define configMAX_TASK_NAME_LEN ( 12 )
#define configIDLE_SHOULD_YIELD 0
#define configUSE_MUTEXES 1
#define configUSE_RECURSIVE_MUTEXES 1
#define configQUEUE_REGISTRY_SIZE 0
#define configUSE_COUNTING_SEMAPHORES 0
#define configUSE_MALLOC_FAILED_HOOK 0
#define configMAX_PRIORITIES ( ( unsigned portBASE_TYPE ) 6 )
#define configMAX_CO_ROUTINE_PRIORITIES ( 2 )
#define INCLUDE_vTaskPrioritySet 1
#define INCLUDE_uxTaskPriorityGet 1
#define INCLUDE_vTaskDelete 1
#define INCLUDE_vTaskCleanUpResources 0
#define INCLUDE_vTaskDelayUntil 1
#define INCLUDE_vTaskDelay 1
#define INCLUDE_uxTaskGetStackHighWaterMark 1
#define configYIELD_INTERRUPT_VECTOR 16UL
#define configKERNEL_INTERRUPT_PRIORITY 1
#define configMAX_SYSCALL_INTERRUPT_PRIORITY 4
/* This demo makes use of one or more example stats formatting functions. These
format the raw data provided by the uxTaskGetSystemState() function in to human
readable ASCII form. See the notes in the implementation of vTaskList() within
FreeRTOS/Source/tasks.c for limitations. */
#define configUSE_STATS_FORMATTING_FUNCTIONS 1
void vApplicationSetupInterrupts( void );
/* Ethernet configuration. */
#define configMAC_0 0x00
#define configMAC_1 0x04
#define configMAC_2 0x9F
#define configMAC_3 0x00
#define configMAC_4 0xAB
#define configMAC_5 0x2B
#define configIP_ADDR0 192
#define configIP_ADDR1 168
#define configIP_ADDR2 0
#define configIP_ADDR3 11
#define configGW_ADDR0 172
#define configGW_ADDR1 25
#define configGW_ADDR2 218
#define configGW_ADDR3 3
#define configNET_MASK0 255
#define configNET_MASK1 255
#define configNET_MASK2 255
#define configNET_MASK3 0
#define configNUM_FEC_TX_BUFFERS 2
#define configNUM_FEC_RX_BUFFERS 4
#define configFEC_BUFFER_SIZE 1520
#define configUSE_PROMISCUOUS_MODE 0
#define configETHERNET_INPUT_TASK_STACK_SIZE ( 320 )
#define configETHERNET_INPUT_TASK_PRIORITY ( configMAX_PRIORITIES - 1 )
#define configPHY_ADDRESS 1
#if ( configFEC_BUFFER_SIZE & 0x0F ) != 0
#error configFEC_BUFFER_SIZE must be a multiple of 16.
xz8987f wrote on Wednesday, October 16, 2013:
it is because you have asked to check for stack overflow in your FreeRTOSConfig.h:
Set it to 0 if you want Stack overflow disabled.
Altough I recommend to have it enabled. Simply add something like this to your application:
void FRTOS1_vApplicationStackOverflowHook(xTaskHandle pxTask, signed portCHAR pcTaskName)
This will get called if a stack overflow is detected during the context
switch. Set configCHECK_FOR_STACK_OVERFLOWS to 2 to also check for stack
problems within nested interrupts, but only do this for debug purposes as
it will increase the context switch time. /
(void)pxTask;
(void)pcTaskName;
taskDISABLE_INTERRUPTS();
Write your code here … */
for(;:wink: {}
If you are using ColdFire V2 (MCF52259) with CodeWarrior, then you might have a look at my Processor Expert component for FreeRTOS: it supports many cores, including ColdFire:
I hope this helps.
