I am trying to build the demo application located in CORTEX_SmartFusion2_M2S050_SoftConsole directory. I followed the instructions to import the project into SoftConsole and I found the RTOSDemo and RTOSDemo_Hardware_Platform in the workspace as expected, but the two projects are almost void (no tools configured) and cannot be built. If I open the Properties/Tool Chain Editor page the following error is shown:
It sounds like the tools have been updated since the project was
created. Are there any instructions for importing an older project into
a new IDE version? Or alternatively, are there any options in the IDE
to change the compiler version being referenced?
I can’t recall, but do recall using SoftConsole recently. Have you
tried getting the head revision code from the SourceForge hosted SVN
repository? Or at least, viewing the repository to see if the project
has been updated since the last release.
I checked the repository but I couldn’t find any update of the project. I tried with SoftConsole v.3.4 and eventually I imported the project correctly. Do you know if in the near future the project will be updated to the latest version of MicroSemi tools? Thanks for the support
