can do port to x86 of PC in WinXP simulation ? very user use VISUAL STUDIO as IDE because is nice for code editing and compiling after it run in target i know can not run as RTOS in NT OS but have you port Freertos to VS for compiling and simulation running only ?
As far as I know VS cannot be used to generate real mode code (unless maybe you have a really old version). Open Watcom provides a free and easy way to compile and debug the code but I have only tried in on Win2K not WinXP.
Can we have a port of FreeRTOS to Visual C++ 2005? (for simulation purposes).
I use VS2005 as editor and test some part of my microcontroller softwares using its good editor and compiler and debugger!
If I have a port for VC++ 2005 then I can test my programs in it.
We can compile programs in VC++ 2005 using GCC C compiler.(we have two compiler for test ,VC++ for some part of my micro projects,GCC for all projects)
Many part of your micro code is in C/C++,and there is not micro dependent parts in it,you can also simulate that parts in VC++.
It also useful for Barry for faster developement of FreeRTOS (new versions with new features)
