Is it possible to call some delay() function with such loop
(for i = 0; i < delay; i++)
in task to get shorter delay/wait time than vTaskDelay()?
I am trying this on LPC2106 with gcc 4.1.1 and it doesn’t seem to work.
Thanks for comments.
The loop does not contain any blocking calls so you are just looping in a task with no context switching. If i is not declared volatile then the compiler might just optimize it away. You could put a vTaskDelay(0) call in the loop.
